Forum » Kaj kupiti » je modro dobro al je samo lepo?GIGABYTE
greenhacker ::
Kolko so vredne GIGABYTE KT 400 plate z USB2.0,firewire,6 chanel sound, raid... A so to dobre plate, kaj mislite. So pa lepe modre barve
kuglvinkl ::
Mislim, da bo Via pri KT400 zopet ubrala svojo pot z KT400A. Namreč, KT400 naj bi imel težave s DDR400. Več na xbit labs.
slawc ::
Kaj jst menim? Ali rabis vse tisto kar ponuja? Potem je (verjetno) vredna.
Tista modra barva... meni je tako in tako vseeno kaksne barve je mamaplata, saj je v ohisju.
Mal se mi pa cudn zdi zakaj nima serialATA. Pa sploh vse novejse plate, ki tega nimajo oz. ne bojo imele so mal cudne.
Sicer je pa vazn da mamaplata dela brezhibno pa da je pocen. Tko kot moja gigabytka zasnovana na i430FX chipsetu No UDMA, no USB, no firewire, no raid, no DIMM, no sound, no lan, no ...
LP,
Slawc
kuglvinkl ::
Why KT400 Does Not Support DDR400
Posted 8/21/02 at 12:37 am by Rat
Although VIA has not declared DDR400 support in the specifications of its KT400 core-logic, we remember that several mainboard manufacturers stated in their announcements that their products can work with such kind of memory. Although the announcements were officials and the companies has not notified us about changing the specs of their products, it is quite strange to see these devices.
According to our sources, VIA KT400 can support DDR400, but only with two banks, as a result, mainboards with DDR400 support enabled, cannot function with more than two DDR400 modules. Furthermore, as I have read over here, the problem may be even worse and these devices are even not able to work with more than one DDR SDRAM DIMM module running at 400MHz. The reason of such strange KT400 behaviour is a bug in the VT8368 north-bridge that VIA has not yet managed to rectify.
I think that the claim above is one of the reasons why the Taiwan-based chipset-maker has decided not to officially support this type of memory in their latest Socket A core-logic. We have not yet performed our usual testing procedures with VIA KT400 board, but our testing of VIA P4X400 based device has shown us that the system stability was below critics and also performance appeared to be quite low when using either one or two DDR400 modules.
Taking everything into consideration, I want to warn our readers about the VIA KT400 mainboards that support DDR400. The statements from manufacturers are definitely reliable, but when buying such product, you should be fully aware that you may not be able to install more than 512MB of DDR400 memory on it, what is even more important, the system may be unstable.
nodes ::
Sedaj bi že res bila dobrodošla kakšna kvalitetna osvežitev v obliki nVidia čipseta. To mi res gre že na ku*** . Deset let ena in ista pesem.
nodes ::
Itak DDR 400 sploh ni standardiziran od JEDEC-a tako mislim, da nobeden ne bo izdal ploščo z uradno podporo DDR 400.
» | Kaj pomenijo številke pri RAM-ih?Oddelek: Pomoč in nasveti | 5108 (4492) | Hayabusa |
» | AMD 2500+ dela samo na 1100mhz 100fsbOddelek: Strojna oprema | 1423 (1059) | DJ MartiNi |
» | RAM problemOddelek: Strojna oprema | 1824 (1601) | drLinux |
» | 6800 gt sparkle (strani: 1 2 )Oddelek: Strojna oprema | 5964 (4958) | jest10 |
» | Kateri ram DDR?Oddelek: Strojna oprema | 2002 (1268) | Clemento |
