Novice » Operacijski sistemi » Windows 7 XP mode pripravljen
krneki0001 ::
> Borchi, pa si ti kej bolj podrobno tvoj compaq "debilizem" pogledal. Moj namreč ima podporo za VM. Ni sicer opcije v biosu, ke je kr stalno vklopljena zadeva.
ja. HP Compaq dx7400 nima VT.
Hmm, imam isto mašino in če zalaufam tale programček (sem dal prej link) mi napiše da imam vse 3 opcije štarane (54bit, DEP in VM).
Wox ::
Wox, Pro Klik normalno deluje na Win 7. Celo na 64bit...
Aha. Sosed mi je rekel da mu ne dela. Bo treba sprobat. Hvala za info.
EDIT: V bistvu nima probleme z Pro klikom ampak z gonilnikom za čitalec kartic, ki ga za Win7 še ni.
- spremenilo: Wox ()
borchi ::
dokler mi ne pokažeš systeminfo izpisa (da gre za HP Compaq dx7400 z zadnjim biosom) in kako v neki virtualni mašini vrtiš 64bitni sistem, ne verjamem nič.
btw, securable ne zna ugotovit, če je VT disable-an v biosu (vsaj na 64bitnih windozih). napiše samo, da procesor podpira VT...
Hardware Virtualization
This processor does offer advanced hardware support for virtualization. However, while running under a 64-bit version of Windows this program cannot execute its 32-bit kernel code to determine whether Intel's VMX virtual machine extensions are being locked on, locked off, or neither. Since there's a chance that your system's BIOS may be deliberately disabling support for hardware virtualization (some do) you should re-run this program, if possible, with administrative privileges under a 32-bit version of NT, XP, or Vista. That will allow SecurAble to run a bit of kernel-mode code in order to determine exactly what's going on. (Note that you can also poke around in your system's BIOS to see whether you're able to find any references to "hardware virtualization" or "VMX", etc.
l'jga
- spremenil: borchi ()
nekikr ::
Wox, doma imam inštalirane Win 7, 64 bit, prvi RC (7100 al kaj je že bil) in mi Pro klik deluje brez problema, za čitalec kartic (ActivIdentity v2.0 USB) mi pa sploh ni bilo potrebno inštalirati driverjev). Sicer je malo smešno, ker mi vedno, ko vstavim kartico v čitalec napiše, da ne more prepoznati naprave, a potem vseeno deluje...
krneki0001 ::
Ja, pa sej to sem jaz napisal. Da ta programček pokaže to troje z zelenim YES.
Ne morem ti pa slikce več narest. Namreč danes so mi zamenjal mašino in sedaj imam E5200 z 2Gb rama, ker je na DX7600 crknila onboard grafična.
borchi ::
jaz sem ti pa napisal, da securable NE MORE ugotovit ali je VT izklopljen v BIOSu ali ne (če ga zalaufaš v 64bit windozih). in tudi meni prikaže zeleno za VT, ker E8400 podpira VT (ki ti pa nič ne koristi, ker intel omogoča, da se VT izklopi v biosu, AMD afaik tega ne omogoča).
> ker je na DX7600
jaz imam dx7400.
> ker je na DX7600
jaz imam dx7400.
l'jga
PrimozR ::
Meni je prikazalo, da je VT podprt, a izklopljen, ko je bil izklopljen v BIOSu. Če gre za isti program.
Xp mode ne nucan, ker ne nucam zastarelih Xpjev. do zdaj s softwareom na Visti nisem imel problemov. oz sem nasel drug program.
da menjam program kateri ne dela in ne OS oz ne iscem neke poti da bi program delal?
tak in tak je vec programov za isto stvar.
- spremenil: mtosev ()
oldguy ::
To več pove o tebi kot pa o "zastarelih" os-ih. Za porniče gledat ti pa verjamem da hitro najdeš alternative...
PrimozR ::
Spet kul. In spet tvoj point? kako je to povezano z novico, ki govori, da je XP mode prešel v RTM fazo?
da ce ne dela native v Windowsu rajse najdem drug program.
a je 100% kompatibilen?
jaz bom probal z Paragon partition manager kateri je za Xp pa bomo videli ce dela.
Ne verjamem, da ti da direkt dostop do trdega diska, tak da pommoje ne bo partition magic, za trdi disk res brez veze, da naredijo direktno podporo. Pomoje Xp mode simulira marsikej, ni to popolna virualizacija, vendar za razliko od drugih, menda dovoli direkten hardwerski dostop do USB,serial itd naprav, torej tiskalniki, ali kiri čudne stare naprave, da jih v ombinaciji z zastarelim programom uporablaš.
V bistvu me res zanima če 100% se da vse naprave, ki so v XP delala v XP mode naštimat.
mtosev:
Eni imajo PC (in program gor) da nekaj naredijo, ne pa da da "iščejo alternative".
Tak kot če bi vozniku mestnega avtobusa rekel, da namesto da odpelje svoj krog, ustavi in gre kupit novi avtobus, ki je bolj moderen. Folk pa čaka. A samo sekundo, ker te potem "strokovno" odstranijo in se odpeljejo z busom. ;)
Lahko pa seveda s _svojim_ busom delaš, kar češ. Lahko ga predelaš na elektriko, pomfri olje, nevtrone... karkoli se ti zazdi kul.
- spremenil: MrStein ()
» | Zakaj imam samo 3GB namesto 4GB rama? (strani: 1 2 )Oddelek: Operacijski sistemi | 19944 (10029) | bobi1992 |
» | Windows 7 XP mode pripravljen (strani: 1 2 )Oddelek: Novice / Operacijski sistemi | 10341 (8225) | MrStein |
» | Windows XP se ne da (strani: 1 2 3 )Oddelek: Novice / Operacijski sistemi | 12067 (8896) | Pyr0Beast |
» | Windows 7 RC 5. maja (strani: 1 2 )Oddelek: Novice / Operacijski sistemi | 10551 (5812) | Tr0n |
» | Zahteve za virtualne XPje (strani: 1 2 )Oddelek: Novice / Ostala programska oprema | 8664 (6368) | tomitza |
