Forum » Strojna oprema » Radeon 9700 je zunaj
kuglvinkl ::
Malce sem razočaran nad dejstvom, da je zunaj šele white paper. Pa vendar, GeF 4600 je samo še old junk.
Postajte vtise, deluzije in vse kar spada zraven.
Še liniki:
THG
Anandtech
Hardocp
Benchmarks:
UT2003 - 1600x1200x32; 4XAA; 16XAF – The Radeon 9700 doused the Ti4600 by about 25%. Now get a load of this, that is with the GF4 running without AA or AF. With 4XAA turned on the Ti4600 was crushed by nearly 300%. The Radeon 9700 simply made quick work of the Ti4600 under this UT2003 demo.
3DMark2001 – Using the default benchmark at 10x7 with no AA nor AF turned on, the Radeon 9700 exceeded the Ti4600’s score by approximately 20%. Where most of the score boost came from was the Nature demo as the Radeon 9700 was posting frame rates of right at 200% of the Ti4600 numbers.
Comanche 4 Demo - 1600x1200x32; 4XAA; 16XAF – Again approximately 25% ahead of the Ti4600 with the Ti running no AA or AF compared to the full on settings of the Radeon 9700.
Last, but certainly not least, a benchmark we don’t use as it is made by NVIDIA, tweaked by NVIDIA, and configured for NVIDIA hardware, the Chameleon demo. At 1600x1200 the Radeon 9700 doubled the Ti4600 scores.
Še liniki:
THG
Anandtech
Hardocp
Benchmarks:
- spremenil: kuglvinkl ()
kuglvinkl ::
Seveda bo hitrejša, še posebej ker govoriva o nVidii. Namreč, drugače je sploh ne bi šli delat. Tu ni cilja, je samo pot.
para-site ::
Mene bolj zanima kolko hitro bojo nove radeone upali spravi na police...in to mislim ne samo 9700, ampak tudi 9000 in 9000pro, ki bo po mojem, če bo le tko poceni kot govorijo, pravi hit. Upajmo, da bo to res late july, bolj realno pa avgusta.
kuglvinkl ::
Kakor jaz vem, je ATi spremenil politiko, tako da, je pot od prestavitve do prodaje izdelka izjemno kratka. Pri nas bo, po mojem mišljenju, dobavljiv r9000 avgusta, R9700 pa na začetku septembra.
tha_man ::
Ampak R9000 bo v bistvu zamenjava za R8500LE, utegne biti celo švohnejšši od njega. R9700 je pa res mean machine
(c) 1982 Sinclair Research Ltd
Malecky ::
Noro...po testu sm zlo happy za stupid kanadčane
Huda mašinca bo tole si že manem roke za 9500 če ne bo preveč oskubljen.
Pa kako nič ne izgublja pri večjih resolucijah res noro.
Senitel ::
Če boš gor tetris špilov ...
OK resno: ne bo velik razlike med 1.5GHz in 2.5GHz z to kartico v špilu ala Doom 3.
Tr0n ::
Heh, sem prebral test. Celo P4 2.5 GHz postane ozko grlo pri nizkih resolucijah in bolj CPU odvisnih igrah. W00t?!
Ampak 250% razlika pri 4xAA, UT2003, 1600x1200 je pa mocna. Ceprav, NV30 bi naj bil po specifikacijah se hitrejsi od ATI 9700.
Joooj, jaz pa se vedno na Voodoo3 3000! Ne, to generacijo bom pa ziher nabavo! ;)
- spremenilo: Tr0n ()
Ahiles ::
Jup za r300 in nv30 bos rabu ene amd2ghz+ al pa p4 2.5ghz+ da bo vsaj ene 80-90% moci stvar izkoristla.
- spremenilo: Ahiles ()
Senitel ::
Pa dober no... VSI DANAŠNJI špili so CPU bound (Unreal Tournamen 2003) included. Ko pa greš delat neki ala Doom 3 pa ugotoviš, da CPU niti ni več tak problem.
Tr0n ::
To bomo pa se vidli ko bodo prvi d3 testi zunaj, pa se bo na veliko testiralo z vsemi moznimi karticami. Can't wait :).
Mislim, da bo kak 9500 model ugoden nakup. Vse candije od 9700 s pocasnejsim ramom in gpu, pa 4x arhitekturo.
Ahiles ::
volk_57 1200 se za gf4 ni dovolj za r300 in nv30 pa prov gotove ne. Delal bo sam ne bos obremenil 100% kartice kajti graficna bo cakala na cpu.
Za r300 in nv30 je greh ce das tako kartico v kaj manj kot 2ghz + dober 19" monitor za 1600 resolucijo.
Hehe, 19" monitor že imam, manjka mi samo še boljši proc, plata, RAM, ....
Vulcano_7+ ::
Men pa boljši monitor, pa R300!Čist uredu bi delal tut na Athlonu XP 1800+
...jst bi biu čist zadovoln!
tha_man ::
Tolk kot ostale kartice ki imajo isto ceno (400$) - torej okrog 130 jurjev, oz. nekaj manj za OEM verzijo, če bo obstajala.
Clemento ::
a je hercules 8500le jajc?ne bi rekel!!!
*Epox 8rda+, XP2600+@stock speed, TT Silent Boost, AS5, Ati AH3650
*Abit NF7-S, XP2500+@2425Mhz, 1.85V(220x11), TT Volcano 12, AS5, Rage128PRO
gregorhomotar ::
Hercules bo probal zmanjšat stroške. Zj če bo na redu isto kot je z 8500 smo na konju ker bomo dali gor bios od 'orginalnege 9700-tke' in bo delala isto sam garancija bo šla ampak bomo prišparali.
Razer was here and now his gone
Clemento ::
zakaj bi sla garancija? saj nisi naredil nobenega fizicnega posega v karto?
ce crkne itak ne grejo gledat kasn bios si mel gor!!! ce je pa kej tazga da sam zajebas flash das pa v pc se eno pc karto pa se enkrat flesnes!
m.i.h.a. ::
Meni ni jasno, kako more nekdo za grafično, katera po enem letu zastara dat 100 000 sit ali pa še več. Pa kaj ste vsi multimilijonarji in vaši očetje so naftni mogotci. Ne razumem. Sam tudi igram igre (ne me razumet narobe), vendar nimam nobene želje dajat 100k za eno kartco, katera bo po dveh letih samo še za v smeti.
Zheegec ::
1. Kdor ima dovolj denarja, mora R300 nujno kupit (spodbujanje svetovnega gospodarstva).
2. Zaradi R300 bodo cene ostalim proizvodom dolgoročno prav gotovo padle (GF4 Ti, Radeon8500).
3. Kupl ga bomo, ko bo okol 50K (kakšno LE verzijo).
GET IT?
GET IT?
_Mortal_ ::
Me prov zanima kdo izbira slikce za škatle.
Is reading in the bathroom considered as multi-tasking?
Matek ::
Kje so cajti, ko je bil Voodoo 1 top preformance kartica in je stal 30 čukov
Malecky ::
400$ je drgač dost cheap za tole kartico, pričakoval sem višjo ceno, sej ne da bi si jo lahko privoščil ampak kolkr je "pred" igricami je zakon cena. Mislim da recimo od Herkulesa lahko pričakujemo vsaj 40$ nižjo ceno in naprej do še slabših izdelovalcev ki so še vedno dobri. Kolkr sm pa vidu da LE verzija ne bo sam mela nižji clock ampak bo oskubljena kar je pa bad...
Senitel ::
MadManMato: Kje so cajti, ko je bil $ še < 100 sit, a... V US je bil tud Voodoo 1 tam $300+, ko je prišel ven...
mislm eni ste pa prov hecni no...zakaj pa bi kdo pricakoval za graficno da bi bla vec kot 400$?? ze to je 3x prevec.sej je cist obicna graficna z nekaj izboljsavami,sej ni iz zlata matr...
pa mislm da tut ni nujno potrebno menjat graficno usake pol leta ane...jst mam se rivo tnt2 pa bom mogoce zamenju sele z nv30 al pa kej tazga.za1x je se ql.pa tut takrat ne mislm dat 100k za graficno ampak ene 40-50k max.
hecni ste eni, res...
tha_man ::
Leta izkušenj
Leta izkušenj
jRk0 ::
Ampak slike so pa kul pr Hercuelsu, pa tudi ati pa nasploh za radeone so kul slike:) no, saj za nvidio tudi, samo hercules pac nima gf4 pa ni lepoh slikic vec:D
haha leta izkusenj....jst sm si prvo 3d graficni pospesevalnik kupu k je vecina od vas se u plenice srala.pa brez zamere
Clemento ::
||_^_||: o cem govoris?
- spremenil: Clemento ()
jureus ::
dr_m kaj lani si si prvic kupo garaficni pospesevalec.
Eni od nas se danes v plenice seremo.
jRk0 ::
torej, ce si ti kupo napriemr pred 15 letimi prvi 3d pospesevalec? i don't think so.
Golden eye ::
ATI RADEON 9700 sploh ni tok bolši v 3dmarku od G4 ti 4600!!!
v glajenju robov je pa zelo hiter
Čakam NV30
Čakam NV30
Zheegec ::
Don't be so shure To je bil testen primerek in pa beta driverji. Bomo videli, kaj lahko še zmore :)
» | nVidia z novima NV28 čipomaOddelek: Novice / Grafične kartice | 2116 (2116) | morphling1 |
» | ATi vs. nVIDIAOddelek: Kaj kupiti | 2114 (1455) | San |
» | Nov kralj med grafičnimi karticamiOddelek: Novice / Grafične kartice | 1850 (1850) | Ziga Dolhar |
» | R300 malenkost...Oddelek: Strojna oprema | 1597 (1143) | _Mortal_ |
