Forum » Pomoč in nasveti » Ima kdo Intel (P35) ICH9R SATA adapter ? (štekanje diska)
Ima kdo tale SATA adapter ?
Me zanima, če ima podobne probleme, kot jaz. Namreč če je v BIOS-u nastavljen na AHCI način, potem med delom ful šteka.
Dolgi opis :
OS almost freezes while copying files to USB harddrive
(kljub naslovu nima veze z USB)
Kratek opis:
How to reproduce:
- prepare a test map with large files* (like C:\a)
- create destination map : mkdir C:\b
- reboot, then login and start a Command Prompt
- perform the copy : cd /d c:\a & copy . ..\b
During the copy, opening the start menu and starting programs, like Notepad, Wordpad, Calculator, Paint, takes very long (up to 60 seconds). Normally they start in a second or two.
For test I used these two files :
6001.18000.080118-1840_amd64fre_Server_en-us-KRMSXFRE_EN_DVD.iso
6001.18000.080118-1840_x86fre_Server_en-us-KRMSFRE_EN_DVD.iso
They can be downloaded freely from Microsoft at
http://www.microsoft.com/downloads/deta...
I used the Intel® Matrix Storage Manager version 7.8 driver.
I also tried Windows 2008 which has a builtin AHCI driver made by Microsoft. With it the same problem happens.
(fajli so zastonj in legalni, da ne bi kdo težil...)
Help!
(na Asus supportu jim ravnokar razlagam, da Windows XP nima AHCI driverja in je treba ekstra instalirat...)
Dolgi opis :
Kratek opis:
How to reproduce:
Help!
ender ::
Imam Gigabyte G33-DS3R plato (G33, ICH9R), v AHCI načinu. Problemov ni bilo ne na Linuxu, niti jih ni na Windows XP x64 (Matrix Storage Manager 7.8). Poleg tega imam tudi ASUS P5W DH Deluxe (975X, ICH7), kjer v AHCI načinu ravno tako ni nobenih problemov (tudi na XP x64 in Linuxu).
Namesti si Process Explorer, in glej porabo CPU (predvsem Interrupts) med kopiranjem datotek.
Cveto ::
Meni na moji plati (glej podpis) dela čisto normalno na ICH9R portih v AHCI načinu.
Si morda naknadno instaliral AHCI driverje, ali si jih naložil že pri instalaciji windowsov? Lahko da zaradi tega zafrkava, ker zna biti težko pravilno naložiti AHCI driverje.
Testiral sem v XP, Visti, Mac Os X in Linux-u.
Sem vse variante probal. Windows + AHCI -> problem
Edino v Linux ni problema.
Bomm čez vikend še žnj-krat windows instaliral (Asus support sprašuje za XP in Visto, kot da se to kak razlikuje od 2003/2008 ...)
Pa sta probala oni test s kopiranjem ?
Ker sicer je problem bolj težko opazen. Ko pa pride, pa ti žge živce.
Najbolj točen test je takoj po rebootu, ko še ni nič v cache.
Razen, da se programi dolgo zaganjajo, je očiten znak tudi, da se podmeniji start menija zelo počasi odporajo, včasih tudi 20 sekund in podobno.
Pa imaš en disk ?
Saj v bistvu je loterija, katero možnost boš izbral. Te izbire sploh ne bi smelo biti (podobno kot kup PIO/(U)DMA izbir pred (deset)letji, ki jih danes nikjer ni, čeprav "spodaj" so še vedno).
RAID je RAID. Nimaš kaj izbirat.
Če pa imaš en navaden disk, pa imaš (vsaj na moji plati) izbiro med temi načini:
- AHCI
- IDE (z nekaj "podnačini")
- RAID (v bistvu lahko imaš ta način, tud če je le en disk)
Razlika med "legacy" načinom ("IDE", "non-native" , veliko imen je za to) in AHCI je, da AHCI podpira NCQ, hot-plug in še kaj (wikipedia vabi).
Zdaj pa nazaj na temo
- AHCI
ender ::
MrStein: ja, jaz sem preden sem oddal sporočilo poizkusil kopirat nekaj VMWare virtualnih diskov najprej med dvema diskoma, potem pa po istem disku, zraven sem pa poganjal Word, Excel, Paint, WordPad itd. Sicer ima 6GB RAMa, samo ker je virtualni disk 20GB, ga sigurno ni dal v cache (programe sem pa vsakič druge poganjal).
Možnost AHCI/Legacy je pa v BIOSu zato, ker ima AHCI neke prednosti (hotplug, NCQ), vendar pa Windows XP in starejši ne podpirajo AHCI krmilnikov brez dodatnih gonilnikov.
Mimogrede, vsaj oba moja BIOSa še vedno dajeta možnost izbire UDMA in PIO načinov za IDE naprave (in za SATA diske kadar krmilnik ni v AHCI načinu).
To si delal v XP x64 ?
Kateri AHCI driver imaš ? (iastor.sys ?)
ender ::
XP x64 SP2, gonilnik Intel 7.8.0.1012 (iaStor.sys)
» | Kako dodati XP k že naloženi visti z AHCI v biosuOddelek: Operacijski sistemi | 3143 (2120) | Gutjerez |
» | OCZ z eSATA 'ključkom'Oddelek: Novice / Diski | 4580 (3090) | Jst |
» | ICH9R in RAIDOddelek: Strojna oprema | 2123 (1619) | T(he) Boss |
» | RAID na Gigabyte P35C-DS3ROddelek: Strojna oprema | 1556 (1318) | tinko1a |
» | sata/ide nepravilno razumevanje pojma!Oddelek: Strojna oprema | 3277 (2950) | Icematxyz |
