Forum » Operacijski sistemi » Pomoč pri prehodu na linux
Tonći ::
Section "Device"
Identifier "Intel Corporation 82740 (i740) AGP Graphics Accelerator"
Driver "i740"
BusID "PCI:1:0:0"
EndSection
Section "Monitor"
Identifier "SyncMaster"
Option "DPMS"
EndSection
Section "Screen"
Identifier "Default Screen"
Device "Intel Corporation 82740 (i740) AGP Graphics Accelerator"
Monitor "SyncMaster"
DefaultDepth 24
SubSection "Display"
Depth 1
Modes "1280x1024" "1152x864" "1024x768" "832x624" "800x600" "720x400" "640x480"
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
Section "ServerLayout"
Identifier "Default Layout"
Screen "Default Screen"
InputDevice "Generic Keyboard"
InputDevice "Configured Mouse"
InputDevice "stylus" "SendCoreEvents"
InputDevice "cursor" "SendCoreEvents"
InputDevice "eraser" "SendCoreEvents"
EndSection
Section "DRI"
Mode 0666
EndSection
Evo to je zapiasm v xorg.conf! Je to povezano z resolucijo!! Se oproscam ya dvojni post ampak editirat se ni dal!
Driver "i740"
BusID "PCI:1:0:0"
EndSection
Section "Monitor"
Option "DPMS"
EndSection
Section "Screen"
DefaultDepth 24
Depth 1
EndSubSection
Depth 4
EndSubSection
Depth 8
EndSubSection
Depth 15
EndSubSection
Depth 16
EndSubSection
Depth 24
EndSubSection
EndSection
EndSection
Section "DRI"
Mode 0666
EndSection
Liker ::
@Tonći:
Sem pogooglal za tvojo graficno kartico, in ugotovil da ima intel i740 od 2MiB do 8MiB spomina. Ce imas 2MiB ali 4MiB, potem 1280x1024 pri 24bitih pac ne gre :)
Poskusi spustiti DefaultDepth na 16 (in ce ne bo boljse se na 15, pa potem 8). manj kot 8 ne priporocam, slika postane namrec negledljiva :P
Tonći ::
Am vse lepo in prav! Ampak zakaj men v xpjih deluje na večji resoluciji! SStvar ni v 1280x1024 ampak v tem da je privzeta resolucije zelo zelo majhna in da se je ne da spremenit!
Tonći ::
Govorim o live cdju že cel čas! In ker resolucija upliva na inštalacijo, ker nmorm normalno vidt okna od inštalacije oz ne morm pritisnt normalno next!
Tonći ::
Evo! Stvar je ratal uredit! Inštalerat, spremenit resolucijo in vse Samo ni mi jasno zakaj po updajtih pišeta 2 verziji kernela? Tko da lahko izbiram med pač tema 2 in xpji:P
- spremenilo: Tonći ()
arjan_t ::
Pri namestitvi novega kernela se pač doda nov vnos v menu.lst, starega lahko tudi izbrišeš če ga ne rabiš
arjan_t ::
če kaj ne dela ipd.
sudo nano /boot/grub/menu.lst
poišči vnose s starim kernelom in jih izbriši ali komentiraj
Quikee ::
S tem nisi nič naredil, ker imaš stari kernel še vedno v sistemu. Drugo pa je, da se "menu.lst" pri upgrade-u nekaterih paketov regenerira glede na kernele, ki jih naje v sistemu (update-grub). Stari kernel moraš vedno ročno odstranit s Synapticom (ali apt-get, aptitude ali pač kaj uporabljaš) - dostikrat pa se čez čas stari kernel da v auto-remove status (če ga nisi sam ročno instaliral oz. se je instaliral preko meta paketov, kot je priporočeno) in ga lahko tako lažje najdeš in zbrišeš.
arjan_t ::
vem, povedal sem mu samo to kaj rabi ...
In kernel ti tudi ne porabi toliko prostora da bi stare odstranjeval, lahko pa tudi zaradi mene
R33D3M33R ::
Ohoho, pa ti. Namreč pri privzeti instalaciji so nameščeni tudi headerji in podobna šara in če odstraniš vse stare kernel pakete pridobiš 171 MB, kar je pri majhnem disku zlata vredno :).
Pač rebootaš, pritisneš ESC in zagotoviš, da zboota novi kernel ter nato preko paket managerja odstraniš starega (torej vse tri pakete s nižjo cifro). Torej 2.6.20-15, če imaš nameščenega tistega s 16tico.
R33D3M33R ::
A še komu wmv video včasih "razpaca" na določenih mestih? Ponavadi ob kakih prehodih?
R33D3M33R ::
Gre se za več videov, prilagam screenshot:
Posnetek je narejen v Kaffeine, mi je pa tudi v MPlayerju naredilo isto.
Film se ponekod vidi lepo, potem se pa vmes razpaca in tak film je bolj kot manj negledljiv.
Datoteka je velika 700kB in dolga 30sekund. Dobil sem jo po mailu. Mogoče je to zaradi visoke kompresije? Nekatere datoteke pa spet delajo brez težav.
Evo to je ta film: http://www.postavi.si/upload/uploads/beer.xmvs.wmv
kriko1 ::
Hahaha
Ne, tukaj se ni razpackal niti en frame. Daj še kakega v analizo, mogoče lahko potrdim za bug-report tvoje distribucije
R33D3M33R ::
Tule se mi pri onem prehodu ko se naliva pivo razpaca: http://www.postavi.si/upload/uploads/3433.wx7v.wmv
Imam pa nameščene gstreamer plugins pa libxine extracodecs.
kriko1 ::
Nope, tudi ta dela. Ne vem ali so wmv nativno podprti v mplayerju ali se uporablja zunanje kodeke. Če se uporablja zunanje kodeke, so potem pri tebi slabi.
R33D3M33R ::
Zdaj sem dodal Binary Codec Package kodeke v /usr/local/lib/codecs/ , kjer jih naj bi MPlayer privzeto iskal, ampak ni spremembe.
kriko1 ::
Če poženeš filmček iz konzole, dobiš kako napako med predvajanjem?
Poskusil sem pri sebi odstranit w32-codecs, mplayer neki zamijavka, ampak vseeno predvaja (pobere ffmpeg video decoder), vendar v tem primeru pride zmazek ravno tam ko se pivo zaliva.
Preglej tvoj output, problem je ker ne pobere zunanjih kodekov, oz prefeira ffmpeg (če si šaril po ~/.mplayer/config).
R33D3M33R ::
V bistvu sem povlekel precompiled verzijo (preko packet managerja). Pognal sem preko konzole in ugotovil v čem je problem:
Torej Mplayer je iskal v win32/ mapi, v readme pa piše, da je codecs/ privzeta vrednost (win32/ naj bi bilo včasih). Med paketnimi verzijami in readmejem očitno ni neke sinhronizacije
No evo, sedaj sem zadevo preimenoval in voila, deluje!
Hvala za pomoč!
Win32 LoadLibrary failed to load: wmvdmod.dll, /usr/lib/win32/wmvdmod.dll, /usr/local/lib/win32/wmvdmod.dll
Hvala za pomoč!
R33D3M33R ::
A je kdo že kdaj uporabljal kak analogen joystick na linuxu? Kljub temu da v lsmod vidim gameport in je joystick priklopljen ga enostavno ne prepozna :/.
Tale test mi pa izvrže tole:
jstest /dev/snd/controlC0
Driver version is 0.8.0.
Joystick (Unknown) has 2 axes ((null), ?)
Segmentation fault (core dumped)
'FireSTORM' ::
Volan preko USB.
Delal sprve, edino z KDE sem ga najprej kalibriral.
Those penguins.... They sure aint normal....
R33D3M33R ::
Moj je pa na gameportu pa ga enostavno ne prepozna. tole skripto sem preizkusil, pa ni bilo uspeha.
Ed004 ::
HOj,
a m lahko kdo pomaga? Namreč, ko sem zagnal gparted, sem videl, da imam še cca 80 GB na razpolago, ampak je particija zaklenjena in jo ne morem uporabljati. Kaj je za narediti, da bi postala uporabna oz. da ji dam pravice za read-write? Se mogoče da združiti s /home?
to je pa screenshot:
- spremenil: Ed004 ()
Brane2 ::
Pri teh zadevah je tako , da imaš lahko do 4 primarne particije na disku.
Če rabiš več, potem moraš tazadnjo- 4 particijo narediti kot extended volume in nato v njej lahko izoblikuješ naslednje, logične particije.
Če imaš to particijo kot primarno, jo moraš zbrisati in narediti "extended", nato pa v njej (sda5, sda6 itd) logične particije, ki se jih bo dalo sformatirat...
Daedalus ::
Pregrdi fonti?
[J.P.Sartre]
[J.P.Sartre]
'FireSTORM' ::
Ed004:
Malo uporabnih besed.
Prijaviš se kot root da lahko sprostiš /home direktorij. Ali pa še bolje zloadaš GParted LiveCD.
Zaženeš in unmountaš particijo ki je na /home in potem daš normalen merge partitions. Ali celo zadnjo particijo pobrišeš in particijo ki je mountana v /home extendaš do maximum size.
mare_ ::
Imam laptop (acer 5520) s touchpadom AlpsPS/2 ALPS GlidePoint in Ubuntujem 7.10. Zdi se mi, da računalnik ne zazna takoj, ko se dotaknem touchpada oz. ko potegnem po njem, ampak da malo zamuja, tako da zgleda vse skupaj, kot da se zatika. Sem se že igral z driverjem, pa nisem nič pametnega ugotovil :) Ima kdo kakšno idejo?
'FireSTORM' ::
Pogledaj na driverjevo uradno stran, morda je kak bug.
To je prvo kar lahko storiš. Ali pa si loadal napačen driver.
mare_ ::
Nah, sem pogruntal, kaj je bilo - en drug program za konfiguracijo touchpada je spreminjal moje nastavitve
Redorange ::
Sem bolj nov v linuxu
a mi lahko napišete katere igre igrate že ko imate volane in joystice
'FireSTORM' ::
http://linux.strangegamer.com/index.php...
Tukaj je en mali seznam dirkaških iger ki delujejo na Linux oz. so napisane posebaj zanj.
R33D3M33R ::
Če ti joystick prepozna ti itak delajo še vse one igre, ki tečejo preko dosboxa in podpirajo joystick.
Vlady ::
Uuu tole lahko preštejem celo na prste obeh rok...
"Lotereya - naibolee točnyj sposob učeta količestva optimistov"
'FireSTORM' ::
Linux ima druge čare in ne rabiš iger ;)
Sicer je pa ena zelo dobra, ki neboš rabil gamepada ali volana:
Battle for Wesnoth
Battle for Wesnoth
Mavrik ::
Mhm, rihtanje vseh miljavžent stvari, ki ne delajo je bolj zabavno kot kerakoli igra.
Vlady ::
Jazagoniš toliko časa, da se sploh ne zavedaš...
'FireSTORM' ::
Lucky me, I didn't have to configure "miljavžent" things.
R33D3M33R ::
Ni mi jasno kak vklopim avtomatsko zaznavanje kodnih naborov v datoteki za recimo Kate in Krusaderjev notranji urejevalnik, ki imata sorodne menije. Fora je, da lahko eno izmed kodiranj izberem (recimo UTF-8), ampak ker delam z datotekami z več različnimi kodnimi nabori, moram vsakič ročno spreminjati vrednosti.
R33D3M33R ::
To sem že gledal, vendar nikjer ni opcije autodetect.
Glede prejšnjega problema s razpacanim videom: nekaj časa nisem vedel kako pripraviti xine engine do tega, da bi raje kot ffmpeg uporabil win32 kodeke. Nato pa sem v engine -> expert options nastavil prioriteto ffmpegvideo na -1 in deluje
R33D3M33R ::
To je nastavljeno, ampak potem forsira UTF-8 za vse odprte in nove datoteke.
c0ck4m0u53 ::
Imam vprašanje, ki se dotika linux sistemov posredno. Pri distribuciji kot office paket uporabljam openoffice 2.3. Zanima me kaj moram nastaviti, da mi bo po končnem ločilu, (pika, klicaj, vprašaj) začelo novo poved z veliko začetnico, zdaj moram to namreč vedno narediti ročno.
» | Debian Gnu/Linux kot workstation (strani: 1 2 3 4 … 37 38 39 40 )Oddelek: Operacijski sistemi | 117399 (33073) | RedDrake |
» | Kako instalirat NVIDIA-driverje v Ubuntu? (strani: 1 2 )Oddelek: Operacijski sistemi | 4964 (3893) | r5r |
» | Ubuntu 8.04 frekvenca osveževanja in resolucijaOddelek: Operacijski sistemi | 2223 (1856) | c0ck4m0u53 |
» | Samba portiOddelek: Omrežja in internet | 1660 (1356) | hruske |
» | Gentoo install (strani: 1 2 )Oddelek: Operacijski sistemi | 4867 (4287) | HerrBaron |
