Forum » Pomoč in nasveti » windows media player 10 mi ne dela !?!?
bunnyrabit ::
ok! zgodil se je predkratkim...hočem poslušat musko..in mi napiše..AN INTERNAL APPLICATION ERROR HAS OCCURED ! .pliz nej mi en pomgaa HVALA
stealth ::
Probaj reinstalirat WMP 10.
Najprej odstraniš:
To roll back from Windows Media Player 10 to a previous version, do the following:
1.
In Control Panel (Category View), click Add or Remove Programs.
2.
Click Remove a program, and then do one of the following:
If you are running Windows XP Service Pack 2, select the Show updates check box (at the top of the list), click Windows Media Player 10 (in the Windows Updates section), and then click Change/Remove.
- or -
If you are running Windows XP Service Pack 1 or earlier, click Windows Media Player 10, and then click Change/Remove.
Potem pa greš normalno na windows update in ponovno namestiš.
Ni sigurno da bo delal, sam je vredno probat.
PS:
drugače ti pa za glasbo priporočam kak winamp ;)
Najprej odstraniš:
1.
2.
- or -
PS:
bunnyrabit ::
ja sej mam winamp..sam ..jebesh to..k hocm gledat..filmcke..ksne in majo sam windows..media player...:S hvala..bom probu...ce bo delal mas pivo od mene :D
bunnyrabit ::
ja tenx...sam tole..je preveč...procedure...razn če mi ti prideš..to narest....system restore...uh ..no bom probu...to bo itak delal TENX
stealth ::
ni treba takoj system restore.
Probaj tole najprej:
1. Click Start, and then click Run.
2. In the Open box, type regsvr32 jscript.dll, and then click OK.
3. Click OK.
4. Click Start, and then click Run.
5. In the Open box, type regsvr32 vbscript.dll, and then click OK.
6. Click OK.
če ti pri tem postopku javi kakšno napako, pa narediš še tole:
2. In the Open box, type msconfig, and then click OK.
3. Click Expand File.
4. In the File to restore box, type the name of the file that you want to restore.
5. In the Restore from box, type the path of the Windows XP .cab file where you want to restore the file, or click Browse From to locate the Windows XP .cab file.
Note The Windows XP .cab files are stored in the I386 folder on the Windows XP CD.
6. In the Save file in box, type the path where you want to extract the new file, or click Browse To to locate the folder that you want.
7. Click Expand.
8. In the System Configuration Utility dialog box, click OK. If you are prompted to restart the computer, click Restart.
3. Click OK.
6. Click OK.
7. Click Expand.
stealth ::
če po vsem tem še kar ne dela, maš pa na tistem linku še METHOD 2 - z urejanjem registra, pa še tisto probaš.
» | Windows 7 Installer (64-bit) - težaveOddelek: Programska oprema | 2817 (2207) | fr!Xy |
» | Remote desktop v XP SP3Oddelek: Pomoč in nasveti | 2464 (1534) | neres |
» | CD-ROM Drive Fail?Oddelek: Pomoč in nasveti | 940 (906) | Climber |
» | Dodajanje bližnice v meni desne tipke na miškiOddelek: Pomoč in nasveti | 1392 (1277) | vres.ales |
» | WIN 2000 BOOT ?Oddelek: Programska oprema | 1396 (1261) | rookie |
