Forum » Izdelava spletišč » [ASP.NET] MySqlDataProvider
greentech ::
Ali mogoče kdo ve kako lahko v web.config dodam MySqlDataProvider, da ga bom lahko potem uporabil v SqlDataSourc-u pri povezavi do baze
[asp:SqlDataSource ID="SqlDataSource1" runat="server" ConnectionString="[%$ ConnectionStrings:conn %]"
ProviderName="[%$ ConnectionStrings:conn.ProviderName %]
Connection String v web config zgleda takole
[add name="conn" connectionString="Server=localhost;Database=baza;Uid=razvoj;Pwd=geslo;" providerName="MySql.Data.MySqlClient" /]
Ko hočem zagnat aplikacijo mi javi
Unable to find the requested .Net Framework Data Provider. It may not be installed.
Torej kako naredit, da bo to delovalo. MySqlConnector imam inštaliran.
Hvala in LP
Grega
Hvala in LP
Grega
CWIZO ::
Imas MySQLov provider med referencami projekta?
hancic.info
I can't uninstall it, there seems to be some kind of "Uninstall Shield"...
» | C# težavaOddelek: Programiranje | 3504 (2350) | mladec |
» | [c#] Vprasanje glede povezave na bazoOddelek: Programiranje | 2432 (2342) | KernelPanic |
» | Internetna stran in domač serverOddelek: Omrežja in internet | 3343 (3179) | Seljak |
» | [ASP.NET] problemOddelek: Izdelava spletišč | 2060 (1710) | Microsoft |
» | [ASP.NET] label povezava z bazoOddelek: Programiranje | 1075 (991) | darkolord |
