Forum » Kaj kupiti » Prenosniki nad 350k
Prenosniki nad 350k
Roach ::
Išem en prenosnik za vsaj 350k, če bi bil sposobn kako novejšo igro bi bil zlo zadovoln, drugače pa me zanima kire firme prenosnikov majo bolšo grafiko, če za igre ni tojk primerna?
hvala
hvala
Zheegec ::
Če ni za igre je slabša, ne pa boljša. Vsekakor bi priporočal Vaiota, sploh zaradi ekrana, sistem je pa tudi zelo OK.
Janez Janša, 29.04.2014
TC lahko izkopiš. Grafa lahko ma 32/64 rama (svojega).
- spremenil: mtosev ()
boštjan ::
TC graficna je...
kot kaže sem malo zarjavel glede hardvera,zato sprašujem kaj bi naj ta TC pomeno.pa pri Comtronu je ceneje
NF7-S,2500+@2200MHz,MSi 5900SP,LCD Philip 190X6,Maxtor DM+9 120GB SATA,
2*256 3200/A KHX, PSU 420W DF chieftek
- spremenil: boštjan ()
Shared mem. Kartica ima nekaj svojega rama bo potrebi pa si sistemskega izposodi.
Key features of the TurboCache architecture:
* Patented hardware and software technologies that render directly to system memory
* A TurboCache Manager (TCM), which dynamically allocates memory for maximum system performance
* Intelligent software algorithms that maximize application performance
* Bidirectional PCI Express® bandwidth, in conjunction with TurboCache architecture, which improves graphics price/performance
Through its unique ability to render directly to system memory, TurboCache fundamentally redefines the price/performance of desktop and notebook PC graphics solutions. With the innovative TurboCache technology from NVIDIA, users looking for an affordable desktop or thin and light notebook solution can now experience the latest graphics and video features of the GeForce 6 and 7 Series GPUs, without compromise.
Roach ::
Js sm si ogledovu Prestigio NOBILE 1590W: Glavne tehnične lastnosti:
- Zaslon: 15.4" LCD TFT 1680 X 1050 WUXGA
- Nabor čipov: Intel 915GM & ICH6-M
- Procesor: Pentium M 1.73 GHz Dothan
- VGA I: Intel® (GMA) 900 128MB
- VGA II: nVidia GeForce 6600 Go module 128MB
- Zvok: 3D Audio AC'97 V2.3 compliant
- Drsna ploščica: Touchpad + 2 gumba
- I/O vmesniki: 3 USB 2.0, 1 IEEE 1394 port, VGA
S-Video Tv-Out, 1x PC Card Type II
- Modem: Internal modem 56Kb,
- Lan: Lan card 10 / 100 / 1000
- Baterija: Lithium-ion baterija
- Teža: 3 Kg
- Ostalo: Bluetooth, 4-in-1 Media Card Reader
- Optična enota: DVD+/-RW +R9 enota
- DDR modul: 512 MB 533 MHz DDR2
- Trdi disk: 60 GB 5400rpm
- Wireless LAN: Intel 2200 B/G wi-fi mini PCI
- Dimenzije: 27,2 x 35,8 x 2,5~3,3 cm
Doplačila:
Windows XP Home Edition SP2 18.900 SIT
Windows XP Professional SP2 Media 33.900 SIT
Centrino™ Pentium - M 1.86 GHz 10.400 SIT
dodaten ram 512 MB DDR333 SO DIMM 200pin 14.400 SIT
hdd 60/7200 15.900 SIT
hdd 80/5400 3.600 SIT
Če ma kir doma prestigia doma, naj pove če je zadovoln z zaslonom in splošnim vtisom!
Hvala
- Teža: 3 Kg
Doplačila:
Hvala
LapD ::
Tist prestigio je iz enaa ane? Jst sm ga naroču pa ga čakam že dva tedna. Sm pa dokupu ram in hitrejši disk. Ko dobim povem več
LapD ::
Ubistvu je že plačan vse skp sam robe še ni. Bo pa baje konc tega tedna tko da ni panike. Sicer pa to ni tema o trgovinah
Zheegec ::
Heh, ta Teal.si je pa drag, pa še Visconte 120 naj bi bil predhodnik 1590W
Pisko ::
Evo jaz imam doma tega prestigia 159W:
1.8 dothan 2mb cache
1gb rama
60gb disk 7200 obr
radeon mobility 9700 256mb
DVD dual layer pekač
Moram reči da je stvar kar hitra.. so pač malenkosti ki se poznajo pri cenejših laptopih kot je ta.. Drugi bo seveda APPLE!!!!
vsekakor priporočam že zaradi dobre resolucije.... ni mi pa jasno zakaj tako rad uporablja ventilator in nimam vroče v sobi..
1gb rama
60gb disk 7200 obr
billy ::
Zaradi grafične verjetno.
kolega ima tudi podobnega kot ti celo z 7200 diskom, pa je rekel da malo sicer laufa ventilator ampka se skor nič ne sliši...a tebi je glasn, al samo laufa vedno?
Bosti1904 ::
Jst mam Fujitsu-Siemens Amilo M1437G. Računalnik,ki je na strani Hermes Nova je podoben mojemu, razlika je v ramih. Jst mam 1Gb. Drugače sem zadovoljen. Display je 1280x800 Crystal Brite, slika je perfektna. Če primerjam s prestigo nobile 1590W,ki ga ima kolega, je boljša. Grafika je Ati radeon x700. Zaenkrat delajo še vse igrce. Nazadnje sem igral NFS:Most wanted in COD II. Zadeve delujejo tekoče. Edini problem je, da se pri zahtevnih operacijah malce greje(igre,itd.). Razlika med prestigo nobile 1590 z geforcom in mojim je minimalna. Geforce je po 3d marku 2005(1024x768) malce boljši (razlika je cca. 90 točk).Dosežen rezultat z mojim je 2053.
Naročil sem ga v bigbangu in nanj čakaj en mesec in pol. (Jeba)
Kot dodatna oprema dobiš zravn še dalinc. S katerim lahko upravljaš InstantON Power cinema. V bistvu je to en predvajalnik filmov,muzk,.., ki deluje v linuxu. V opisu računalnika na uradni strani pa piše da zadeva deluje brez operacijskega sistema. Kaj je pa linux? :)
Cena:399 990 SIT
Cena:399 990 SIT
- spremenil: Bosti1904 ()
Picero ::
Hellou,
kaj bi mi svetovali za en prenosnik, potrebujem za obdelavo fotografij (zaslon vsaj 1400x1050, ce ze ne 1680*1050), pa skoraj obvezno nonshared video kartico, da bo projekcija cimbolje laufala. Ali je tole OK ali dobim lahko se kaj boljsega:
HP NC8430
Procesor:Intel Core Duo T2500 2.00-GHz, 667-MHz FSB, 2-MB L2 cache
Mobile Intel 945PM Express Chipset
Zaslon 15'4'' TFT WSXGA (1680*1050)
Pomnilnik: 1024 MB 677 MHz DDRII SDRAM
(razširljiv do 4 GB, prosta reža)
Trdi disk 100 GB 5400 rpm
DVD+/-RW - SM Double Layer
Grafika ATI Mobility Radeon X1600 256 MB
Mrežna kartica 10/100/1000 in analogni modem V.92
Brezzična mrežna kartica WLAN 802.11a/b/g in BlueTooth
Vmesniki 1xser. 1xVGA, 1xS-Video, 1xIR, 1xFireWire,
3xUSB 2.0, PCMCIA 1x Tip I/II, SD/MMC čitalec kartic, port replikator
ambient senzor(prilagajanje svetilnosti zaslona), priklop za potovalno baterijo
Enhanced Dual point (Point stick, touch pad), TPM Security module!!!
Li-Ion baterija (do 4,5h)
Dimenzije: 2,8(spredaj) x 25.9 x 35.5 cm – 2.77 kg
Windows XP Professional (angleški in slovenski)
Garancija 1 leto
Cena: 365.200 SIT
HP NC8430
Garancija 1 leto
Cena: 365.200 SIT
» | Koliko je vreden tale prenosnikOddelek: Kaj kupiti | 1186 (980) | BALAST |
» | Vrednost laptopa (HP)Oddelek: Kaj kupiti | 2526 (1739) | MI5Ek- |
» | Toshiba ali HPOddelek: Kaj kupiti | 2285 (2137) | Svizec69 |
» | Ker prenosnik od teh dveh naj izberemOddelek: Kaj kupiti | 3133 (2883) | kmhslo |
» | Se en nakup prenosnika - tokrat do 400.000SITOddelek: Kaj kupiti | 2467 (1800) | rokleb |
