Windowsi vkljucujejo backdoor za NSA
...According to Fernandez of Cryptonym, the result of having the secret key inside your Windows operating system "is that it is tremendously easier for the NSA to load unauthorized security services on all copies of Microsoft Windows, and once these security services are loaded, they can effectively compromise your entire operating system". The NSA key is contained inside all versions of Windows from Windows 95 OSR2 onwards.
"For non-American IT managers relying on Windows NT to operate highly secure data centres, this find is worrying", he added. "The US government is currently making it as difficult as possible for "strong" crypto to be used outside of the US. That they have also installed a cryptographic back-door in the world's most abundant operating system should send a strong message to foreign IT managers".
http://www.heise.de/tp/r4/artikel/5/526...
fahrenGONE ::
E nkrat so ze govorili o tem in je bilo res, MS je priznal da so dali nek NSA kljuc noter. Potem pa je vse potihnilo do sedaj. To je lahko tudi osnova za skupinsko tozbo, saj MS "zagotavlja" varne tehnologije za podjetja. Kako lahko potem dajo backdoor noter? To je nateg kupcev.
Kitajci so zavrnili Windows za uporabo v vladnih PCjih. Nic cudnega.
#000000 ::
Ma ne verjamem, dokler kdo ne dokaže 'pa ne tko da napipše članek' LP
A demonstration "how to do it" program that replaces the NSA key can be found on Cryptonym's [extern] website.
klik na link vrne tole.
The requested URL /hottopics/msft-nsa/ReplaceNsaKey.zip was not found on this server.
Brez komentarja. 'sploh'
  • spremenilo: #000000 ()
Monster ::
..in zakaj nebi temu verjel ... ce gledas da winse uporabla 90% kompjuterov potem je to logična poteza našega globalnega policaja :)
Ka zaboga...
#000000 ::
Dobr se bom posul s pepelom, verjamem da je kaj takega mogoče izvest, ampak da pa se dogaja pa ne verjamem dokler nekdo ne dokaže, kot sem rekel 'ne z člankom' če vejo da to je, pol tud vejo kako dela ipd. in če zna folk skrekat al pa porihtat programe keri so dost bolj zaščiteni od win zakaj pol ni zunaj kakega cracka al pa patcha da bi to sranje 'če obstaja' disablal ?? LP
fahrenGONE ::
Pred par leti ko je bili prvic govora o tem, so dokazali in je bilo tudi na TV in vecjih straneh kot so slashdot.org in wired.com. Poglej malo arhive tam...
Spajky ::
Ko na frišno inštaliraš wXP, najdeš v registru poleg 3 nujnih userjev še ena dva z zelo kriptičnim imenom (ki jih winsi nikjer ne pokažejo drugače) ... 8-)
#000000 ::
Ja no sej mene zanima ker file je to al pa user, če mi lahko kdo razloži ??
Pyr0Beast ::
Bi blo zanimivo ime pogruntat :)
urban99 ::
Najbrž neumno vprašanje - obstaja kak patch za tole? :8)
Daedalus ::
Obstaja, ja. Sliši na ime Linux:P
[J.P.Sartre]
fahrenGONE ::
To tudi pove koliko lahko res preberejo pri NSA, CIA in FBI. Ce se uporablja moderna kriptografija bore malo.
Nova runda zgražanja nad Facebook-om zarad prodajanja podatkov
Oddelek: Problemi človeštva
63105 (2687) zee
Regin nov zelo dodelan vladni vohunski program (strani: 1 2 )
Oddelek: Novice / Varnost
5422164 (19120) ulemek
Afera Prism: podjetja naposled priznavajo posredovanje informacij
Oddelek: Novice / NWO
3919098 (16381) Hayabusa
NSA pwns us all?
Oddelek: Omrežja in internet
362189 (2189) In Extremis
Palladium!?!
122090 (1893) andrej
