ali sem izbral pravo plato in grafiko?
bado ::
Kupujem novo plato in grafično.
Zanima me ali priporoča kdo kaj boljšega v tem cenovnem razredu (+- 5k po komponenti)
-- MSI K8N Neo4 Platinum, nForce4 Ultra (dual PC3200 DDR)
-- PowerColor Radeon X800 (Bravo), 256MB, GDDR3, PCIe, Retail
. Memory 256 MB 256-bit DDR3 SDRAM
. Core / Memory Speed 392/350 MHz
. Memory Bandwidth 22.4 GB/sec.
. Pixel Pipelines 12 extreme parallel pixel pipelines
. Pixel Fill Rate 4.7 Gigapixels /sec.
. RAMDACs 400 MHz DACs
. Output DVI-I X2 / VIVO
glede obstoječih komponent imam procesor A64 3200+ @2600mhz (do sedaj na nforce 3, 10x260fsb€), rami pa so apacer pc4000 cl3
hvala za vse informacije v naprej
sid911 ::
nisi cen napisal..
sicer bi pa ti za grafo x800xl priporočal
1. Asus P8P67 LE | i3 2100 | HD 3850 | 2x4GB | 320 GB + 2 TB
2. FSC Amilo PRO V3515 ( T2060;2 GB;80GB)
bado ::
mas prav glede XL
cene so nekje priblizno eneka, odvisno od stacun do stacune
pa glede plate?
bado ::
ker sem gledal x800xl, zdaj gledam še x850pro cena je enaka!!
kateri je boljši? pa še to a se da na HDTV priklopiti vga oz. dvi monitor
od power colorja recimo
http://www.tul.com.tw/global/productlist.aspx?folderid=1&cat1=50&cat2=135&cat3=328
GPU RADEON® X850 PRO
Memory 256 MB 256-bit GDDR3 SDRAM
Core / Memory Speed 507/520 MHz
GigaFLOPS 200 billion floating point operations/sec.
Transform Rate 780 million vertices/sec.
Memory Bandwidth 34.56 GB/sec.
Pixel Fill Rate 6.24 Gigapixels /sec.
DirectX Support 9.0
OpenGL Support 2.0
Output DVI-1 / TV-Out / Video-in / HDTV
Operating systems : Microsoft® Windows XP, Microsoft® Windows 2000
Bus 16x lane PCI Express
in
http://www.tul.com.tw/global/productlist.aspx?folderid=1&cat1=50&cat2=124&cat3=324
GPU RADEONTM X800 XL
Core / Memory Speed 400/490 MHz
Memory Bandwidth 31.4 GB/sec.
Pixel Pipelines 16 extreme parallel pixel pipelines
Pixel Fill Rate 6.4 Gigapixels /sec.
DirectX Support 9.0
OpenGL Support 2.0
Operating systems : Microsoft® Windows® XP, Microsoft® Windows® 2000
Bus PCI Express
Suli ::
Si 100% da procesor in matična plošča pašeta skupaj?:8)
bado ::
na sliki se vidi da ima dvi, tv-out in vga
hdtv mi je malo novejsi pojem (a je to enak priklop kot dvi?)
bado ::
kolikor vem pašeta :)) zakaj ne bi? :)
tu je link do plate socket 939
http://www.msi-computer.de/produkte/main_idx_view.php?Prod_id=430
Katero grafično kartico naj kupim? (strani: 1 2 )
705069 (4250) ross|e20
Kero Grafično do 45k?
171689 (1356) Roadkill
Kje najceneje do 9800pro
161596 (1098) humanoid
Pozor !!! powercolor 9800 pro samo 128 bit
432758 (1704) DjTonic
R9800pro
281647 (1299) `DoC
