Forum » Programska oprema » Win XP security
Win XP security
JanezH ::
Kako nastavim v WinXP security, npr. da nek direktorij lahko odprem samo jaz, ostali uporabniki pa ne?
V Win2K si samo z misko kliknil desni gumb in izbral opcijo SECURITY - pri WinXP jo pa ni!!!
Witboy ::
Hja tuki je pa malce drgac. Kot prvo ti priporocam da si malce preberes help.
Drugace je pa v tem sistemu da pac dolocis ze pri user settings da hoces svoje dokumente met pod nadzorom etc.
JLP ::
K z desno klikneš na folder/file drž tipko Control in pol izber Properties.
Live long and prosper!
ToniT ::
Če nisi prijavljen v domeno, se to zdaj imenuje private folders (če si prijavljen v domeno, ostane isto, kot pri Win2000) - kako se pa to naredi, pa piše v Help-u:
To make your folders private
Open My Computer.
Double-click the drive where Windows is installed (usually drive (C:), unless you have more than one drive on your computer).
If the contents of the drive are hidden, under System Tasks, click Show the contents of this drive.
Double-click the Documents and Settings folder.
Double-click your user folder.
Right-click any folder in your user profile, and then click Properties.
On the Sharing tab, select the Make this folder private so that only I have access to it check box.
Notes
To open My Computer, click Start, and then click My Computer.
This option is only available for folders included in your user profile. Folders in your user profile include My Documents and its subfolders, Desktop, Start Menu, Cookies, and Favorites. If you do not make these folders private, they are available to everyone who uses your computer.
When you make a folder private, all of its subfolders are private as well. For example, when you make My Documents private, you also make My Music and My Pictures private. When you share a folder, you also share all of its subfolders unless you make them private.
You cannot make your folders private if your drive is not formatted as NTFS. For information about converting your drive to NTFS, click Related Topics.
Related Topics
Open My Computer.
Notes
Related Topics
andrej ::
2 nastavitvi:
1. V folder options izklopi User fimple file sharing.
2. v Security settings pa pod Secutiry Options izberi Classic pri nastavitvi NEtwork access: Sharing and security model...
Paramedic ::
Js pa namesto helpa raje berem pomoč 'ob kazalcu'. Tisto, ko desno-klikneš na izbiro in daš 'pomoč' ali 'več o...' ali kar pač piše. Tak da sem jaz to o simple folder vedu
End transmission.
ToniT ::
Ljudje ne samo da ne berejo Helpa, ne berejo niti tega kar piše na ekranu - rajši pokličejo koga da jim pove tisto, kar itak piše na ekranu (moje izkušnje).
Hvala za pomoč pri nastavitvah za security - WinXP uporabljam šele 3 dni in se počasi privajam...
JanezH ::
Uff to sem ugotovil ze pred tremi dnevi (ko sem dobil zadnji odgovor v postu, ki mi ni ravno pomagal) in ne boste verjeli - s pomocjo helpa.
» | SMB povezava Winows 10 s Synology NASOddelek: Operacijski sistemi | 3062 (2328) | dukedl |
» | Dodajanje bližnice v meni desne tipke na miškiOddelek: Pomoč in nasveti | 1383 (1268) | vres.ales |
» | Kako v Win2k premakniti mapo Documents and Settings?Oddelek: Operacijski sistemi | 1758 (1724) | Mercier |
» | Logitech MouseWare bug (?)Oddelek: Pomoč in nasveti | 2113 (1709) | Swiwer |
» | Iščem alternativo vudujuOddelek: Kaj kupiti | 1753 (1517) | Arthur |
