Forum » Programska oprema » Kako naj naložim program v linux-u
KoKi ::
mislim da bom kr k3b dalje uporabljal ...
# cdrecord -scanbus
Cdrecord-Clone 2.01a28 (i686-pc-linux-gnu) Copyright ? 1995-2004 Jörg Schilling
cdrecord: No such file or directory. Cannot open '/dev/pg*'. Cannot open SCSI driver.
cdrecord: For possible targets try 'cdrecord -scanbus'. Make sure you are root.
cdrecord: For possible transport specifiers try 'cdrecord dev=help'.
1. sicer sem noob za linux samo device pg* za writer/cdrom mi je novo. :)
2 # whoami
root
3. # cdrecord dev=help
Supported SCSI transports for this platform:
Transport name: sg
Transport descr.: Generic transport independent SCSI
Transp. layer ind.:
Target specifier: bus,target,lun
Target example: 1,2,0
SCSI Bus scanning: supported
Open via UNIX device: not supported
Transport name: pg
Transport descr.: SCSI transport for ATAPI over Parallel Port
Transp. layer ind.:
Transport name: ATA
Transport descr.: ATA Packet specific SCSI transport
Transp. layer ind.: ATAPI:
Target example: ATAPI:1,2,0
Transport name: ATA
Transport descr.: ATA Packet specific SCSI transport using sg interface
Transp. layer ind.: ATA:
Transport name: RSCSI
Transport descr.: Remote SCSI
Transp. layer ind.: REMOTE:
Target specifier: rscsi@host:bus,target,lun
Target example: REMOTE:rscsi@host:1,2,0
ok mam dva writer-ja. en dvd/rw (sec. master) drug cd/rw -dvdrom (sec. slave), kaj pa bi ta red od mene pa mi ni jasno
iz manuala: If no dev option is present, cdrecord will try to get the device from the CDR_DEVICE environment.
se spremenil iz yamaha na liteon in se seveda nic ni spremnilo ...
# cdrecord -scanbus
2 # whoami
root
Transport name: sg
Transp. layer ind.:
Transport name: pg
Transp. layer ind.:
Transport name: ATA
Transport name: ATA
# hackable
CCfly ::
cdrecord dev=ATAPI -scanbus
Moja napaka. Vse CDROM-e imam na SCSI. Za IDE moraš dati povsod še ATAPI zraven.
npr.:
cdrecord dev=ATAPI:0,0,0 ...
npr.:
KoKi ::
ta
nekak mi je zdaj ratalo prvi rw posnet, samo kot prvo nisem mogo z cevenjem, kot drugo pa sem za kreiranje iso ouprabo "-l" opcijo pa namesto da bi dalo polna imena je naredlo zmes neke "__".
# hackable
CCfly ::
Pri mkisofs moraš dodati stikala za Joliet in Rock Ridge, drugače boš imel ISO9660 datotečni sistem na CD-ju (precej omejene dolžine datotek in seveda tisti _).
Kar ti pa pri pipah | ni delovalo ?
KoKi ::
ja zdaj je vredi naredlo: mkisofs -J -R -max-iso9660-filenames -o img.iso /dir.
pri pipah se mi zdi ko da nekaj zmes manjka:
# mkisofs /dir | cdrecord dev=ATAPI:0,1,0 -v
cdrecord: No tracks specified. Need at least one.
# hackable
Zakaj si dal -max-iso9660-filenames ?
To je nestandarden hack s katerim itak ne boš nič dosegel, saj že imaš Joliet oz. RR za dolga imena.
Da bere z stdin, moraš cdrecord-u dati parameter -, torej :
# mkisofs -J -R /dir | cdrecord dev=ATAPI:0,1,0 -v -
CCfly ::
Še pomišljaj daj na koncu.
mkisofs ... cdrecord ... -
Eh bo pa dvakrat zapisano.
- spremenilo: CCfly ()
Gandalfar ::
Sam da razlozim tale minus se za vse ostale, ki berejo pa jim ni kaj prevec jasno.
cdrecord [parametri] input.iso
In zdej ce hocemo uporabiti pipe moramo namesto input.iso dati minus ( - ), ker to programi pove da naj bere iz stdin.
cat foo | grep 'barf' -
s programom cat npr. izpisemo datoteko foo, ki pa jo | redirecta k grepu. Zdej grep je navajen, da bere iz stdin in mu ponavadi ni treba dat - ampak, lahko pa tudi, ce zelimo pokazati na primeru.
KoKi ::
jup zaj pali :)
MrStein: moti me to da napise, npr.:
Using KLAUD000.MP3;1 for /dir/Klaudija - Bice Bolje/Klaudija - 08 - Crni Andjele.mp3
samo je vseeno vredu posnelo.
# hackable
gobec ::
mam eno uprašanje imam linux red hat 9,pa ne znam instalirat programou.Kako naj instaliram npr. mplayer??
CCfly ::
Inštalirati moraš rpm paketke. Se pravi pobereš ustrezne paketke z interneta in jih potem kot root namestiš, ali z ustreznim grafičnim orodjem ali pa v lupini.
Druga možnost bi bila uporaba ustreznega upravljalca paketov kot so yum, apt, ... Ta možnost je boljša že zaradi lažjega nadgrajevanja programov.
Na tej strani imaš že pripravljene rpm paketke in tudi navodila.
No krasno že spet me je nekdo prehitel
Jaka_3000@hotmail.com ::
Ludi moji miški se je zmešal!!!
bilokaj kliknem mi koče kr premaknat kaj naj nardim da bo spet normaln!!!
Aja pa še en uprašanje glede windows xp professional
če kdo ve kaj o xp-jih
mojmu koligu sm šou gor nalagat xp pol pa je še na začetku use dober zgledal sm lahk formatiro disk (NTFS) pol je začel neki nalagat ko je pa naložl je pa nanov zagnal računalnik pol je pa prišl do tja ko začne bootat s cd-ja pa ne napisal error loading sistem...
zakaj (če kdo ve)
ker bi mogl po pravem kolk se spoznam pridit v grafično okolje začet nalagat!!
zakaj (če kdo ve)
CCfly ::
tak kot da bi mi hotl kopirat al neki tacga pa use ko hočem odpret morm pouure klikat če mi hoče odpret!!
premaknat mi hoče use kar kliknem al pa je že dost da grem z miškinim kazalcem kr črez
kak naj nardim da bo spet normaln?????????????????'
CCfly ::
Se pravi ko premakneš miško se ona sama premika, dokler ne pride do roba zaslona, ali je kaj drugega. V tem primeru bi bilo dobro vedeti, če si spreminjal karkoli v /etc/X11/XF86Config.
ja nepredvaja mi jih (sj si mi reku naj grem na tisto stran sam jaz se s tam nič ne znajdem.)
kaj naj nardim??
kaj naj nardim??
hahaha
nism paničaru
sm sam uprašo kaj naj nardim?
-besede povejo učasih čist drugač ko pa je edn uresnic mislu
nism paničaru
[root@localhost jaka]# yum install xmms-mp3
Gathering header information file(s) from server(s)
Server: Fedora Core 2 - i386 - Base
Server: Fedora Core 2 - i386 - Released Updates
Finding updated packages
Downloading needed headers
gimp-devel-1-2.0.4-0.fc2. 100% |=========================| 22 kB 00:00
iiimf-protocol-lib-1-11.4 100% |=========================| 5.3 kB 00:00
xorg-x11-xauth-0-6.7.0-5. 100% |=========================| 68 kB 00:00
xorg-x11-Xvfb-0-6.7.0-5.i 100% |=========================| 68 kB 00:00
mozilla-dom-inspector-37- 100% |=========================| 3.8 kB 00:00
squirrelmail-0-1.4.3-1.no 100% |=========================| 27 kB 00:00
finger-0-0.17-24.i386.hdr 100% |=========================| 2.7 kB 00:00
gstreamer-0-0.8.3-2.i386. 100% |=========================| 6.6 kB 00:00
libgnome-devel-0-2.6.0-3. 100% |=========================| 4.7 kB 00:00
gnome-session-0-2.6.0-4.i 100% |=========================| 7.1 kB 00:00
ipsec-tools-0-0.2.5-4.i38 100% |=========================| 2.7 kB 00:00
libwnck-0-2.6.0.1-3.i386. 100% |=========================| 5.1 kB 00:00
iiimf-emacs-1-11.4-46.1.s 100% |=========================| 5.9 kB 00:00
php-odbc-0-4.3.8-2.1.i386 100% |=========================| 6.0 kB 00:00
xorg-x11-ISO8859-2-75dpi- 100% |=========================| 74 kB 00:00
gnumeric-1-1.2.8-2.i386.h 100% |=========================| 30 kB 00:00
iiimf-x-1-11.4-46.1.svn15 100% |=========================| 5.7 kB 00:00
fam-0-2.6.10-9.FC2.i386.h 100% |=========================| 4.1 kB 00:00
xorg-x11-syriac-fonts-0-6 100% |=========================| 69 kB 00:00
libbonobo-0-2.6.2-1.i386. 100% |=========================| 6.0 kB 00:00
php-mysql-0-4.3.8-2.1.i38 100% |=========================| 6.0 kB 00:00
php-devel-0-4.3.8-2.1.i38 100% |=========================| 13 kB 00:00
gaim-1-0.81-1.FC2.i386.hd 100% |=========================| 20 kB 00:00
..............in tako naprej
ka je vredu tole??
ka je vredu tole??
CCfly ::
Zaradi tega ker redno ne updataš sistema bi rekel. Poglej si malo yum, ker je koristno orodje. Napiši man yum in malo preberi, da boš poznal vsaj osnove dela z njim.
Sergio ::
Jaka, ne mi zameriti, ampak ti potrebuješ še precej osebne rasti, da boš lahko samostojno namestil operacijski sistem (da poleg osebne rasti ne omenjam znanja in iznajdljivosti).
Razumem, da se vsakemu kaj zalomi, ampak ti enostavno samo sprašuješ ene in iste stvari, nekatere tako nesmiselne, da bi te prosil, da prepustiš (vsaj za zdaj) namestitev katere koli distribucije Linuxa kakšnemu znalcu.
Z uporabo (redno uporabo) bo pa prišlo tudi znanje, kako zadevo namestiti.
Naj ti bo Google in man v pomoč.
Tako grem jaz, tako gre vsak, kdor čuti cilj v daljavi:
če usoda ustavi mu korak,
on se ji zoperstavi.
ok
sam a je to kaj narobe če velik sprašujem???
ko si bom prišu gor bom vrjem mi nehu tolk sprašvat ker men tud ni tolk do tega
aja na googlu pa je večina v angleščini
pol ko je v yumu naredl tist je čist nakonc napisal da ni mogl najdit xmms-mp3
[root@localhost jaka]# yum search xmms
Looking in available packages for a providing package
No packages found
Looking in installed packages for a providing package
Installed package: xmms-devel.i386 1:1.2.10-2.p matches with
xmms-devel
Installed package: xmms-skins.i386 1:1.2.10-2.p matches with
xmms-skins
Installed package: xmms.i386 1:1.2.10-2.p matches with
xmms
Installed package: xmms-flac.i386 0:1.1.0-4 matches with
xmms-flac
4 results returned
tole mi je napisal
kaj na pa zj???
No packages found
xmms-devel
xmms-skins
xmms
xmms-flac
4 results returned
tole mi je napisal
kaj na pa zj???
CCfly ::
Očitno imaš en lev repozitorij nastavljen.
Tukaj naj bi se zbirali podatki o repozitorijih. Na strani ti lahko sam zgenerira nov yum.conf, da se ne boš mučil.
CCfly ::
Repolsitories; yum, release 2, Tracker links; Submit Query (dobiš poivezave in opis)
Repolsitories; yum, release 2, Apt/yum config files; Submit Query (dobiš avtomatsko generirano config datoteko)
CCfly ::
Ja s tistim kar najdeš dopolni ali pa prepiši vsebino tvoje datoteke /etc/yum.conf. Namreč v tej datoteki imaš pot do repoziterijev, iz katerih yum vleče dol headerje in paketke.
» | Obnovitev sistema ne delujeOddelek: Pomoč in nasveti | 1976 (1910) | mpucko6 |
» | Spletna mrzlica zaradi HD-DVD ključaOddelek: Novice / Avtorsko pravo | 5710 (4110) | CaqKa |
» | LG GSA-4120B dela probleme pri pečenju DL DVD+RjevOddelek: Strojna oprema | 1626 (1435) | mtosev |
» | Fujitsu Siemens notebook in linuxOddelek: Operacijski sistemi | 1093 (1007) | dr.J |
» | PLEXTOR BurfProof unicuje cdje - prosim pomagajte!Oddelek: Pomoč in nasveti | 1552 (1306) | krho |
