Forum » Kaj kupiti » Nakup napajalnika
Nakup napajalnika
JIM22 ::
Zanimam se za nakup enga dobrga napajalca. Zanima me Antec in Enermax. Zdaj pa ne vem katerga.
Antec 550W Power Supply, Model "TRUE550" -RETAIL
Specifications:
Type: ATX
Maximum Power: 550W
PFC: No
Power Good Signal: 100-500ms
Hold-up Time: >= 17ms at Full Load
Efficiency: >= 68%
Over Voltage Protection: +5V trip point (+6.5V); +3.3V trip point (+4.1V); +12V trip point (+14.4V)
Overload Protection: Latching Protection+5V @(47A);+3.3V @(48A);+12V @(18A)
Input Voltage: 115/230 VAC
Input Frequency Range: 47-63 Hz
Input Current: 10.0A for 115VAC; 6.0A for 230VAC
Output: +3.3V@32A; +5V@40A; -5V@0.5A; +12V@24A; -12V@1A; +5VSB@2A
MTBF: 80,000 hrs. @ 25ºC
Approvals: UL, TUV, CB, VDE, FCC CLASS B, DEMKO, NEMKO, SEMKO, F
ali
Enermax 460W Power Supply for AMD K7 & Pentium4, Meet AMD K7 and Intel ATX +12V 1.1 and ATX 2.03 version, Model "EG465AX-VE (W)FCA"
Specifications:
Type: ATX
Maximum Power: 460W
PFC: Active
Hold-up Time: 17ms min.
Efficiency: 70% min.
Over Voltage Protection: +5V 5.6-6.9V; +3.3V 3.7-4.5V; +5VSB 5.6-6.9V
Overload Protection: 105%~160%
Input Voltage: 94V~264V AC
Input Frequency Range: 47Hz-63Hz
Input Current: 9.5A/ 2.5A
Output: +3.3V@35A; +5V@35A; -5V@1A; +12V@33A; -12V@1A; +5VSB@2.2A
MTBF: 100K hours at 25ºC
Approvals: UL, cUL, VDE, DEMKO, NEMKO, SEMKO, FIMKO
Če ta model ni za AMD, pol pa mogoč enga iz tega LINKA
Bol mi diši Enermax saj ima na 12V liniji kar 33A. Cena je nekje enaka. Če kdo ve zakaj imajo nekateri enermax-i kar dve liniji 12V (1 in 2). pProsim svetujte mi kaj se splača vzet. Imam pa Nforce2 plato.
Specifications:
Type: ATX
Maximum Power: 550W
PFC: No
Efficiency: >= 68%
ali
Specifications:
Type: ATX
Maximum Power: 460W
PFC: Active
Digitalni marketing, nastop na spletu v naročnikovem imenu.
Vsi na FB pridružite se itVision :)
- spremenil: JIM22 ()
definitivno anteca (pa ne zarad moci)...
JIM22 ::
Zakaj pa pol. Enermax ma na liniji 12V kar 33A, Antec pa 24A
ja kaj pa potem sprasujes...pa kup enermaxa, ce misls da je boljsi. nihce ti ne brani.
JIM22 ::
Ja vidiš to MEDENA. DR_M-a ne smeš preveč resno jemat, ker zmeram nekaj bluzi. Kaj pa drugi.
stvar je cist preprosta...
1. najprej razmisl kaj hoces.
2. ne primerjat med sabo BMWja 750 pa WV passata...
3. mal starejsi test, novejsi test...
edit: JIM22 takih tem je blo tuki ze miljon...a misls da se men da usakmu pof *** retardancu posebi razlagat?? jest nikol ne govorim tja neki v 3 dni, sm raj tih, kot da to delam. samo povem tiste ugotovitve, do katerih smo ze prisli v drugih temah.
- spremenil: Dr_M ()
MEDENA ::
ejga ni treba takoj v napad...retardanc je pa grda beseda, čisto brezveze uporabljena...
take it easy...
take it easy...
MEDENA ::
ma bluzimo vsi mi k smo preveč za pcji !
itaq ni mislil v negativnem smislu ....
relax DUDE
relax DUDE
no ja...kakorkoli....se en dober link
JIM22 ::
Saj vidiš. Gledam teste pa nekako ne najdem ENERMAX-a. Rad bi slišal kakšno pametno od nekoga ki ima HARD OC in kater napajlnik mu dobr služi. DR_M za tebe pa vem da še zdaleč nisi med njimi. Tako, da se ne zaganjaj. Moderator pa lahko po mili volji pobriše kar ne sodi zraven.
ne res nism HARD OCer, ker mi za razliko od drugih, fotr ne daje kesa za comp.
hudica...ce ze primerjas take napajalnike med sabo, primerji anteca TC 550 in ENERMAX EG651P-VE FMA 550W.
to je to, ce hoces res dober napajalnik... ne mores pa jabolk pa hrusk primerjat.
Keyser Soze ::
No mene pa zanima kje v tej Sloveniji dobiti štacjon, ki mi bo lahko ponudil vplogled v cenovno razliko med True 480 True 550 in true Control 550.
Mislite, da je True 480 dovolj močan za prihajajoče zverine(Grafične, CPU) in mi bo zvesto služil kar nekaj časa ali naj rajši raskiram še tistih par tisočakov in si ubodem True 550. Denar mi en raste ravno na drevesu.
PA še glede Control verzije True 550. A je tista kontrola, ki ti jo nudijo za voltaže dobrodošla ali je bolj kot ne neuporabna.
OM, F, G!
TP480 je vsekakor dovolj mocan, za vso prihajajoco periferijo, ker gre za zelo kvaliteten napajalnik, z locenimi linijami.
kar se pa tice nastavljanje napetosti...zadeva je zelo uporabna, ker si ob morebitnem padcu napetosti, popravis zadevo.
Keyser Soze ::
JE uporabna. OK
Ampak kaj pa glede na razliko v ceni. Mailsim, da okrog 15 tisočakov. True480(jabolko) za okrog 30 tisočakov in Control550(hruška) za okrog 45 tisočakov. Mislim, da ni vredno. Kajne?
OM, F, G!
no nisi res ksn hudo extremen OCer pol se ti res ne splaca.
lohk pa tut mal pogledas tagana ki ga majo pri mlacomu, je povsem enakovreden antecu (isti princip), pa se drag ni...cca 23k sit.
en review tagana. se povsem zlahka primerja z najnovejsimi enermaxi, pa se precej cenejsi je.
Keyser Soze ::
MAma mia. Sam kablov ma pa tud za eno JEK. Pol metra + 15cm še za vsak dodaten molex!!
Zelo dober napajalnik. Mi je všeč. Tako po zmogljivosti kot po hrupu.
Le tisti ATX adapter iz 24 pinov na 20 je malo preveč. Še več gužve v ohišju.
Pa predolgi kabli. Mnogo preveč zmede. Že zdaj sem pri skoraj vsakem napajaču rezal žice ker jih je bilo mnogo preveč.
OM, F, G!
hja...je pac BTX kompatibilen, zato konverter.
so pa vsi kabli lepo prepleteni, tko da jih ni problem zvit skupi, da ne zavzemajo dragocenega prostora.
TribesMan ::
Tudi jaz bi ti bolj kot Anteca trenutno priporočal 480W Tagana, ki je res narejen kot se šika. Tudi med posameznimi kosi je zelo malo razlike (imajo zelo konstantno proizvodnjo, tle antec malo trpi, saj se lahko zgodi da dobiš precej slab kos...). Pa tudi tišje laufa in malo cenejši je. Všeč mi je tudi to da so kabli prepleteni in tako lepo zmanjšajo EMI... pa še lepo zgleda.
Kar se pa same kvalitete elektrike tiče pa ima Tagan nekoliko manjši ripple kot antec, kar je dobro... Ostalo pa je isti šmorn...
TribesMan
TribesMan
Keyser Soze ::
Sam bemti šmorn.
A mislite, da bi se dalo kje dobit kakšen bolj kompakten pretvornik za napajanje? Tiste periferne kable bom že lepo pospravil iz poti.
Ampak tisti veliki dongl tam nad grafiko bi mi pa res paral živce.
OM, F, G!
TribesMan ::
Keyser Soze:
Mislim da lahko ta 24pinski konektor priklopiš na 20 pinski konektor na plati, ker na tem konektorju so samo dodani 4-je pini. Seveda je pogoj da je okoli ATX konektorja plac in da ni nobenih izrastkov iz plate, ker pol lahko narediš kak stik. Sam v osnovi pa konektorja pašeta endn na drugega... Tud 20 oinski konektor lahko utakneš v 24 pinskega... sam ni pa priporočljivo... Dočim obratna modifikacija ni problem, če je le plac na plati...
TribesMan
TribesMan
Keyser Soze ::
Aja. Sem mislil, da je konfiguracija pinov kaj drugačna oz. zmešana. Če so pa samo dodani pini potem pa OK. Placa je pa zadost na NF7 ampak samo na desni strani ATX konektorja.
Bom premislil, pa bom videl. Na ceniku od MLacoma iz 5.4.2004 je Tagan cenjen še na 28.680. In mu je v enem mesecu kar padla cena. Zakaj??
OM, F, G!
MEDENA ::
TAGAN TG480-U01 480W EPS12V 22.914 24.120
zakaj ?
ja konkurenca....$ slab ....
isto kakor 2500+M iz 29900 na 22500.....
zakaj ?
» | Kater PSU za hard OC (strani: 1 2 3 4 … 9 10 11 12 )Oddelek: Kaj kupiti | 27920 (16466) | LittleDevil |
» | Kateri napajlnik za DFI lanparty?Oddelek: Kaj kupiti | 2487 (1900) | Caligula |
» | napajalnikOddelek: Kaj kupiti | 2129 (1489) | Trdi |
» | napajalnik (strani: 1 2 )Oddelek: Strojna oprema | 5489 (4888) | TribesMan |
