Forum » Navijanje » SiSoft SAndra rezultati za procesorje (arithmetic, MM)
Rekec ::
Napišite vaše rezultate pri Sisoft Sandra ali prilepite sliko!
Zanima me "CPU Arithmetic benchmark" in "CPU Multi-media benchmark"!!
Post naj bo v taki obliki:
SLIKA(ni nujna)
PC
Procesor:
Rami:
Trdi disk:
CPU- navito:
Frekvenca: (original in navita)
Voltaža: (original in navita)
FSB: (original in navit)
Multiplier: (original in navit)
Sisoft SAndra rezultati:
Arithmetic b.:
MM b.:
SLIKA(ni nujna)
PC
Procesor:
Rami:
Trdi disk:
CPU- navito:
Arithmetic b.:
MM b.:
Rekec ::
kajzer ::
PC
Procesor: athlon xp 2600+ tbred
Rami:A-data 256 ram (pc 3200)
Trdi disk:Maxtor 80 gb
CPU- navito (trenutno):
Frekvenca: 2080/2200
Voltaža: 1,65/1,7
FSB: 166/220
Multiplier:12,5/10
Arithmetic b.:d8403/w3475
CPU- navito (max):
Frekvenca: 2080/2400
Voltaža: 1,65/1,875
FSB: 166/240
Multiplier:12,5/10
Arithmetic b.:d9079/w3765
Še slika:
Voltaža: 1,65/1,7
FSB: 166/220
Multiplier:12,5/10
CPU- navito (max):
Voltaža: 1,65/1,875
FSB: 166/240
Multiplier:12,5/10
Še slika:
- spremenil: kajzer ()
Tomay ::
PC
Procesor:Celeron 2,4
Rami:Transcend TS64MLD64V3F5
Trdi disk: Maxtor 6Y080L0
CPU- navito: Celeron 2,4 @ 3,2
Frekvenca: (original in navita)2400Ghz - 3200Ghz
Voltaža: (original in navita)1,53V - 1,53V
FSB: (original in navit)400 - 533
Multiplier: (original in navit)24 - 24
Arithmetic b.:8939 - 1851/4211
MM b.:12704 - 16222
MM b.:12704 - 16222
Voodoo 4Ever
Hammer ::
PC
Procesor: athlon xp 1800+ tbred
Rami:Kingston value ram (pc 2700)
CPU- navito
Frekvenca: 1533/2410Mhz
Voltaža: 1,775
FSB: 133/195?
Multiplier:11.5/12.5?
Še slika:
CPU- navito
Voltaža: 1,775
FSB: 133/195?
Še slika:
- zavaroval slike: Tic ()
Wad@ ::
BoLhCa ::
PC
Procesor:P4c 2.4c HTT
Rami:2 x 256Mb TwinMOS/Winbond CH5 PC3200
Trdi disk:2 x 80Gb SATA Maxtor Raid 0
CPU- navito:
Frekvenca: 3.221MHz HTT
Voltaža: 1.525v @ 1550v
FSB: 200 @ 268
Multiplier: 12 @ 12
Prvi sz Intel power-jam=))
PC
CPU- navito:
FSB: 200 @ 268
Multiplier: 12 @ 12
Rekec ::
e niso lestvice naredli za sisoft sandra, pa sn pač ustvaro novo temo.
Bog je reko znajdi se!
OwcA ::
"Uradne" lestvice ni, ker gre za precej obskuren test.
GUFY ::
Procesor: 1700+
Rami:Corsair PC 2700
Trdi disk:Maxtor 40 GB
CPU- navito:2736 MHz
Frekvenca: 1463 MHz@2736 MHz
Voltaža: 1.5V@2.1
FSB: 133@228
Multiplier: 11@12
Rekec ::
še ma kdo kake rezultate?
Glede na kaj je odvisno kako "daleč" lahko navijem FSB. (jaz na žalost ne morem spremenit FSB/DRAM ratia (plata asus a7v8x-x)
pluto ::
PC
Procesor:AMD Athlon XP 2000+
Rami:3x256MB SpecTek 0100c620 PC2100
Trdi disk:Seagate st330610a
CPU- navito:
Frekvenca: 1666/1849
Voltaža: 1.65/1.65
FSB: 133/148
Multiplier: 12.5/12.5
Sisoft Sandra rezultati:
Arithmetic b.:6834 MIPS / 2723 MFLOPS
MM b.: 10453 it/s / 10745 it/s
CPU- navito:
Voltaža: 1.65/1.65
FSB: 133/148
Tugo ::
Procesor: 2500+
Rami: Twinmos 3200 Winbond
Trdi disk: WD 160G
CPU- navito:
Frekvenca: 1833 / 2500
Voltaža: 1.40 / 1.85
FSB: 166 / 200
Multiplier: 11 / 12.5
Arithmetic b.: ??? / 9475/3942
MM b.: ??? / 23622/25060
Ko/ČE zrihtam hlajenje MOSov, napišem še popravek.
lp, T.
Trdi disk: WD 160G
CPU- navito:
FSB: 166 / 200
lp, T.
- spremenil: Tugo ()
Moonman ::
Procesor: P4 2.8C
Rami: 2x256MB HyperX 3500
Trdi disk: WD 80Gb
CPU- navito:
Frekvenca: 2800 / 3570
Voltaža: 1.525 / 1.675
FSB: 200 / 255
Multiplier: 14 / 14
Arithmetic b.: 11439 MIPS - 4499/7849 MFLOPS
Trdi disk: WD 80Gb
CPU- navito:
FSB: 200 / 255
Multiplier: 14 / 14
Edi999 ::
Procesor: AMD Athlon XP 2600+
Rami: 512Mb PC2700 DDR XTREME Technology
Trdi disk: IBM 80Gb
CPU- navito:
Frekvenca: 2083 / 2226
Voltaža: 1.65 / 1.75
FSB: 166 / 171
Multiplier: 12.5 / 13
Arithmetic b.: 8336/3443
MM b.: 20049/20504
S tem, da sem začetnik pri navijanju!! To je prva stvar ki sem jo navil sprve!!!
Trdi disk: IBM 80Gb
CPU- navito:
FSB: 166 / 171
MM b.: 20049/20504
OwcA ::
Saj te gleda (in ti kaže jezik ) deset odgovorov višje.
OwcA ::
Em, 15k -- 15 tisoč slovenskih tolarjev, torej pribljižna cena tega procesorja, kar je skoraj trikrat manj kot je potrebno odšteti za 2,4C.
Gufy lep dosežek, a kaj ko pa si pozabo povedat da zadeva ni stabilna,če pa se motim pa kapo dol
BoLhCa ::
lol zdej sm kopcnu kaj hoce povedat=)) ja to je pa res ja vsaj ene 15k je bil zihr drazji... Razlika je samo, da ga jst tko stalno gonim, pr teb pa mislim da ta rec ni stabilna za 24/7... ali pač?
bom jutri zutri povisu fsb, tok de pihnem tvoj score de bos mel mir=)
LittleDevil ::
Procesor: P4 2.8C
Rami: 1x512Mb PC333
Trdi disk: WD 80Gb, Maxtor 80Gb
CPU- navito:
Frekvenca: 2800 / 3640
Voltaža: 1.525 / 1.600
FSB: 200 / 260
Multiplier: 14 / 14
Arithmetic b.: 11031 MIPS - 4524/8112 MFLOPS
Ko dobim nove rame pa poročam naprej.
Rami: 1x512Mb PC333
CPU- navito:
FSB: 200 / 260
Multiplier: 14 / 14
sajko ::
Procesor: Barton 2500+ (mobilc)
Rami: 2x256mb Twinmos 3200
Trdi disk: Maxtor 40GB 7200rpm
CPU- navito: 2636 mhz
Frekvenca: 1830 @ 2636 mhz
Voltaža: 1.5v @ 2.05v
FSB: 100 @ 229
Multiplier: 11x @ 11.5x
- spremenilo: sajko ()
OrkAA ::
sajko: zdi se mi, da maš nekoliko slabe rezultate za tako frekvenco. Jest dobim podobne s 2300Mhz
OrkAA ::
Sm sicr mal narobe zaokrožu, ker že dolg nism navijov ampak vseeno...
Se mi zdi, da bi lahko sajko mel veliko več...
P.S.: Procesor je barton 2600+, voltaža pa default
- spremenil: OrkAA ()
Strijc ::
Vem da je offtopic samo mene zanima kako to da: če pogledate na rakcovo sliko tisto na kateri je napisana konfiguracija njegovega sistema (system properties) mu spodaj pod COMPUTER piše AMD Athlon (tm) 1800+ pod tem pa 2.04 GHz.... vem da ima navitega samo tudi moj je navit pa mi tam več ne piše AMD Athlon (tm) 1800+ ampak samo AMD Athlon (tm)... Zakaj to???? Pa v CPUZ mi tudi samo AMD Athlon piše...... Ima mogoče kdo razlago?????
sajko ::
OrkAA: hm.. mozno sam glede na gufyjev rezultat (s 100mhz visjim clockom) se mi zdi kr vredu. Nevem nej kdo k se na to bl spozna kot jaz pove.
Drugac pa tvoj rezultat niti prblizno ni bliz mojga (grejo zloooo pocas gor tiste stevilke :)
OrkAA ::
Vem vem Ubistvu jest ne navijam kej preveč in sem imel ob pisanju prvega posta v glavi le približen rezultat
Rekec ::
kaj bi lahko kak admin al pa kdo drug dal to temo na vrh, ker mislim, da je pomembna za navijanje, saj nam daje rezultate pri benchmarku, lahko jih primerjamo, ali pa se posvetujemo pri navijanju.
sajko ::
Caligula ::
Jz dobim ta tazgornji Dhrystone ALU na 2400@2400 9100 pik.
Pol pa zdej studiram, ce cem prodat ta proc za cca 15 jurjev in kupit mobilca. Pa ne vem, ce je vredno, da bi dubu se kakih 200 mhz vn.
Kaj pravte?
Kaj pravte?
kajzer ::
Glede na to da je tvoj tbred in z nakupom pridobiš npr. 200MHz, se zaradi večjega pomnilnika pozna za približno 100MHz.
Za primerjavo: 2600 tbred dela na frekvenci 2.08GHz, 2600 barton pa na frekvenci 1.91GHz
Samo za to bo rabi verjetno manjšo voltažo in bo bolj hladen, množilnik boš lahk spreminju tako da boš dosegu visok FSB, kar se tudi zelo pozna. kolker mi je znano imajo 2400+ množilnike od 13 naprej, zato ne moreš dosegati visokih FSB-jev.
Caligula ::
Mam mnozilnike od 5 dalje. Tko, da FSBji niso problem. Mam navadnega desktop AMDja 2400+
xenon74 ::
evo fantje malo eksotike:
moja stara abitka KT7a v1.0 malce nadgrajena
PC
Procesor: TbredB 2100+
Rami: 2x 256MB PC133
Trdi disk: WD 20GB 2mb + MAXTOR 80GB 8mb
CPU- navito: 2.27GHz
Frekvenca: 1729 / 2267
Voltaža: 1.6 / 1.7 (1.66)
FSB: 133 / 133
Multiplier: 13x / 17x
Arithmetic b.: ALU 8437 / FPU 3358
MM b.: 20910 / 22234
Sicer porine še krepko višje ampak bi rabil močnejši PSU.
X74
PC
FSB: 133 / 133
X74
http://setiweb.ssl.berkeley.edu/team_display.php?teamid=30319
GUFY ::
Da mal obudim tole temo se moj rezultat z Mobilnim Bartonom 2500+
PC
Procesor: Barton M 2500+
Rami: 2x 256MB pc 2700
Trdi disk: MAXTOR 120GB 8mb
CPU- navito: 2727 MHz
Voltaža: 1.5 / 2.0 V
FSB: 133 / 202
Multiplier: 13x / 13.5
Arithmetic b.: ALU 10005 / FPU 4036
PC
FSB: 133 / 202
» | O navijanju z viševanjem FSBOddelek: Navijanje | 1457 (1253) | Veron |
» | FSB vs. RAM LatencyOddelek: Navijanje | 1284 (1082) | PEK- |
» | NF7-S 2.0, Barton 2500+ M, Twister 512ddr 4300Oddelek: Navijanje | 1342 (1020) | bond007 |
» | Baza RAM timingovOddelek: Navijanje | 2699 (1635) | DimmniBurek |
» | Kako je z Athloni 2500 XP (strani: 1 2 3 )Oddelek: Kaj kupiti | 7919 (5596) | Tarzan |
