160-gigabajtni PS3 Slim
vir: engadgetNovice » Igre » Prihajata bel in prostornejši PS3
mugensport ::
Ful je folka, ko bo kupl zadevo ravno zaradi njim ljubše barveTut sam nekaj takih poznam. Men se pa jebe tut, če mam drobovje konzole zunaj ohišja sam da street fighter seka
Kron ::
Baje, da Uncharted 2 obremeni od 90 - 100% cell.
Samo je še lufta pri optimizaciji za Uncharted 3.
=**=C64=**=
- spremenil: Kron ()
Bananovec ::
Po meni znanih podatkih samo 80%, no možno je tudi da 100%.
Me pa prav zanima kaj bodo v štirki spacali vkup.
Regards, Apple
Regards, Apple
Kron ::
Naughty Dog
V bistvu je Among Thieves trikrat bolj zahtevna od Drake's Fortune.
Upam na odlično nadaljevanje, do sedaj fenomenalne serije.
Christophe Balestra, co-president of Naughty Dog, spoke with Ars about the technology behind Uncharted 2, the hugely anticipated follow-up to one of the PS3's best games: Uncharted: Drake's Fortune. "First of all, we fill the Blu-ray 100 percent, we have no room left on this one. We have 25GB of data; we're using every single bit of it."
For the first game, Balestra estimated that they used around 30 percent of the power of the SPUs, now the team was able to use them to 100 percent capacity. Naughty Dog understands the Cell processor, and knows how to get it to sing. "The ability to use the RSX [the PS3's graphics processor] to draw your pixels on the screen, then you use the Cell to do gameplay and animations—we kind of took the step of using the Cell process to help the RSX . All those things are done on the Cell processor," he explained. "It really helps us getting that quality of lighting per pixel; the amount of computation is pretty crazy."
=**=C64=**=
Super bi bilo, če bi lahko že pri nakupi izbrali recimo med 10 različnimi barvami.
Isto velja za TV-je in ostalo šaro.
Hmm... oranžna
Hmm... oranžna
PrimozR ::
http://www.colorwarepc.com/
Sicer je pa to no-go, preveč enih zalog, različnih delov za proizvodnjo, itd. itd.
morbo ::
Menda se je 40 let od tega v Jugi dalo dobiti eno leto bele fičkote, drugo leto modre. A na trgu konzol je dandanes isto?
Berserker ::
Prej si ga moral še par mesecev vnaprej naročit, potem pa si dobil takšnega kot ti ga oni servirajo.
Jst ::
S sendvičem v vratih. :)
» | Prihajajo Gran Turismo 5, Crysis 2 in Portal 2Oddelek: Novice / Igre | 3696 (3124) | barocco |
» | Sony osvežil PS3 SlimOddelek: Novice / Procesorji | 10978 (9599) | _Enterprise_ |
» | PlayStation 3 Slim tudi uradno (strani: 1 2 )Oddelek: Novice / Konzole | 13183 (9045) | Jst |
» | PlayStation 3 cenejši, polovica Xbox 360 umre (strani: 1 2 )Oddelek: Novice / Konzole | 11950 (8241) | PrimozR |
