Forum » Strojna oprema » Random restart računalnika
Pero_SLO ::
Obračam se na vas za pomoč, ker se mi računalnik sam od sebe restarta kadar ima nizko porabo energije. Torej restarta se mi samo ko sem v desktopu, browserju, gledam filme,... Kadar igram igre se ne restarta.
V Event viewerju mi javi napako Kernel-power ID 41 z razlago: The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Data:
Še opis računalnika in sistema:
OS: Windows 10
GPU: GIGABYTE GV-N960WF2OC-4GD 4GB
MB: GIGABYTE Z170-HD3P DDR4
PSU: EVGA SuperNOVA GS 550W
CPU: INTEL Core i5 6600T 2.7GHz OEM LGA1151
RAM: ram nevem na pamet moram odpreti kišto, upam da bo šlo brez, je pa podprt s strani matične
Prosim za pomoč, ker sem že kar obupan... Resetira se lahko 5x na dan ali pa nikoli...
Hvala in lep pozdrav,
Peter
Event Data:
BugcheckCode 0 BugcheckParameter1 0x0 BugcheckParameter2 0x0 BugcheckParameter3 0x0 BugcheckParameter4 0x0 SleepInProgress 0 PowerButtonTimestamp 0 BootAppStatus 0 Checkpoint 0 ConnectedStandbyInProgress false SystemSleepTransitionsToOn 51 CsEntryScenarioInstanceId 0
OS: Windows 10
Peter
konspirator ::
http://download.gigabyte.ru/manual/mb_m...
#35
Daj na enabled.
w10 je upgrade ali clean install ?
Tu en pravi da se mu potem, koj eš el 1x v safe mode, sistem v idlu ne ugaša več.
https://www.tenforums.com/general-suppo...
bios je zadnji ?
Da ni to https://www.reddit.com/r/Windows10/comm... ?
Power management nastavitve daj na "max performance".
ter
Went to Power Supply-->Change when Computer Sleeps-->Change Advanced Power Settings-->Hard Disk-->Turn off Hard Disk After...
999999999999
#35
Power Loading
Enables or disables dummy load. When the power supply is at low load, a self-protection will activate causing
it to shutdown or fail. If this occurs, please set to Enabled. Auto lets the BIOS automatically configure this
setting. (Default: Auto)
Daj na enabled.
bios je zadnji ?
ter
999999999999
- spremenilo: konspirator ()
Pero_SLO ::
#35
Power Loading
Daj na enabled.
To imam na enable.
Clean.
Bom probal, če
Da ni to https://www.reddit.com/r/Windows10/comm... ?to ne bo pomagalo. Danes ob 19:02 je bil zadnji update, ob 19:03 je bil crash :P . Lahko da je to, bom spremenil.
Ostalo bom probal, če update ne bo pomagal. Hvala zaenkrat :) .
LP,
Peter
Pero_SLO ::
konspirator je izjavil:
#35
Power Loading
Daj na enabled.
bios je zadnji ?
ter
999999999999
Updejtal sem vse driverje in se bios in sedaj se skos restarta.... Takoj ko vpisem geslo za v windowse se mi po prikazu desktopa racunalnik restarta.... Zdej pa res nic ne morem z racunalnikom....
Mi sploh kej pametnega preostane razen servis?
Hvala in lp,
Peter
m0LN4r ::
Sposodi si od nekoga napajalnik za 1 dan.
https://ref.trade.re/38mvdvxm
Trade Republic 38MVDVXM
Pero_SLO ::
konspirator ::
bios na default nastavitve.
Kako delajo winsi v safe mode ? Kako dela live linux (lubuntu) ?
Naredi kopijo pomembnih podatkov in namesti win še 1x (ali jih namesti na kak drug hdd), vmes starega odklopi.
m0LN4r ::
ECO mode na napajalniku sm izklopu in sedaj se še ni resetiral.... Če je to to...
LP,
Peter
Pac mozno je ja, da napajalnik vec ne dela tako kot bi moral.
Pero_SLO ::
Bolj logična razlaga je, da je PSU poddimenzioniran na ECO mode.
Vse kar sem zasledu za ta "ECO" mode je, da do določene obremenitve PSU-ja ne vklopi ventilatorja... Sicer pa je bil včeraj zvečer spet reset računalnika... Zdej imam od soseda 450W noname napajalnik notri pa da vidim, če bo kaj bolje. Sicer ni isto vse priklopljeno(2 diska in DVD enota nisto priklopljene in CPU je samo na 4 pine in ne na vseh 8), ampak zaenkrat dela :) .
LP,
Peter
m0LN4r ::
PSU ni stabilen, to bo to. Nabavi nekaj kvalitetnega.
Kaksne komponente imas, graficna, procesor?
Pero_SLO ::
m0LN4r ::
A se ti resetira oz. dobis bluescreen?
Za foro naredi novega uporabnika, restartaj prijavi se vanj in cakaj. Izklopi kak screensaver ali podobno sranje.
PS:
Pred tem si instaliri: Bluescreenview in pokazi kaj ti izpise, kateri driver to dela.
PS:
- spremenil: m0LN4r ()
Pero_SLO ::
PS:
Ta program mi nič ne javi po resetu računalnika.
Ena komponenta mi serje, CPU, Ram ali celo MB... Tudi od windowsov blue sreen mi nič ne javi...
LP,
Peter
- spremenil: Pero_SLO ()
za ram maš memtest.
Pero_SLO ::
updejtaj bios in izklopi c7/c6 state
Nevem kaj je to c7/c6 state in kje se to naredi?
Bom probal se memtest, ce bo ratal do konca narest :) .
Je pa zelo neumna napaka to. Kolikor sem bral po netu jo nekateri odpravilo softwersko drugi pa hardwersko.... Uglavnem brez glave in repa zadeva. Softwerske zadeve sem pomojem ze vse sprobal, pa nic ne deluje. PSU sem zamenjal in ni nobene razlike... Kar sem opazu je, da je update biosa iz f5 na f21 zadevo samo poslabsal in to zelo...
Pero_SLO ::
Če bootaš v live linux se tudi reboota ?
http://www.legitreviews.com/what-enabli...
Live linux zaenkrat deluje stabilno. c6/c7 state disabled ali enabled ni nic pomagal. Sosed mi je omenil, da lahko da mi zna mrezna kej zajebavat, ker mi tut internet obcasno neha delovati brez razloga... Da ima kaksno sleep funkcijo... Ce kdo ve kaj vec o tem.
LP,
Peter
Pero_SLO ::
Memtest sem pustil delovati cez noc in po petih zakljucenih ciklih ni nasel nobene napake... Kaj mi priporocate? Nalozim ponovno win10 ali win7? Ima kaksno vezo ce naredim install USB iz uradne MS strani ali s svojega nedelujocega sistema za win10?
LP,
Peter
LP,
Peter
m0LN4r ::
Jaz sem imel en primer, ko je bil za to kriv MS driver za mrezno/wifi kartico.
Memtest sem pustil delovati cez noc in po petih zakljucenih ciklih ni nasel nobene napake... Kaj mi priporocate? Nalozim ponovno win10 ali win7? Ima kaksno vezo ce naredim install USB iz uradne MS strani ali s svojega nedelujocega sistema za win10?win10
LP,
Peter
naredi iz ms websita. kaj si misli s tem iz svojega nedelujočega sistema?
Pero_SLO ::
konspirator ::
V biosu, v safe mode tudi ?
Normal mode windows, pred tem izklopi kabel od mrežne kartice.
Bios je F21 http://www.gigabyte.com/Motherboard/GA-... ? Si ga resetiral na privzete nastavitve ?
Preveri delovanje sistema brez gpu GTX 960 (uporabi igpu HD Graphics 530).
Zakaj Z plata in T cpu ? Sistem je nov/ koliko star ? Če nov, razmontiraj vse skupaj in sestavi ponovno.
Kdaj/kako se je problem pojavil ? Po MS CU https://slo-tech.com/novice/t699086#crta ?
konspirator ::
evga monitor orodje za psu
http://www.evga.com/support/download/sh...
eco mode:
http://www.evga.com/support/faq/afmview...
Si priklopil dodatno napajanje za gpu, cpu&mb (atx_12V_2x4) ?
http://download.gigabyte.ru/manual/mb_m... stran 4 zgoraj
gpu
http://www.gigabyte.com/Graphics-Card/G...
Recommended PSU 400W (with one 6-pin & one 8-pin external power connectors)
Ne tlači noname 450W jajc v tvoj sistem.
eco mode:
gpu
Pero_SLO ::
Bom probal.
Sem.
Bom probal.
T cpu ker je bolj varcen. Z plata, ker naj bi bila dobra in kompatibilna s cpujem. Sistem je star leto in pol in tezave so od samega zacetka, vendar so bile znosne(reset mogoce 1x na dan, sedaj neprestano). Nimam se MS CU updejta nalozenega.
Bom nalozil.
Imam v PSU 2x4 in CPU 2x4 napajanje. GPU imam priklopljen na PSU preko dveh locenih kablov na PSU(tudi ce je na isti kabel ni bilo razlike). MB imam tako kot mora biti in periferijo tudi.
gpu
Tega imam http://www.gigabyte.com/Graphics-Card/G... in je priklopljeno na dveh locenih 6 pin kablih na PSU. Napajalnik je tudi 550W.
Sem samo za testiranje v desktopu in tezava je ostala.
Hvala za ideje.
LP,
Peter
konspirator ::
Zgrešil si koncept, intelovi cpu od s775 dalje so varčni tudi brez raznih T variant.Sistem s starim i5 1150 & 8 let starim psu porablja 35W v idlu.
Z plata je za OC.
Kot bi na pagani zondo montiral nalite gume, tako je pri tebi.
Vsaka čast za živce ! Nadomesten psu: Super flower platinum 550/650, xfx xtr 550/ts 650.
hojnikb ::
atom iz istega obdobja (v mojem primeru x205ta) porabi 0.7W v idle na screen off
#brezpodpisa
hojnikb ::
potem pa desktop z istim procom cca 2W v idle
(for some reason ta porabi več kot notebook)
#brezpodpisa
- spremenil: hojnikb ()
m0LN4r ::
To se slisi sumljivo. Kako pogosto se resetira, mislim v kakem casovnem intervalu?
Pojdi v BIOS v oddelek HW Monitoring oz. temu podobno in pusti tam cez noc.
Ce to zdrzi, naredi bios updejt.
Pero_SLO ::
Zdej sem našel neko povezavo v event viewerju pri crashu. Vedno se izvršijo poleg Event 41 Kernel-power še Event 172 Kernel-power in 4x Event 55 Kernel-processor-power(za vsa 4 jedra) in še Event 2 MEIx64 z opisom: Intel Management Engine Interface driver has started successfully.
Bom poiskal kaj to točno naredi in če imajo tudi drugi kakšne težave s tem driverjem..
LP,
Peter
m0LN4r ::
Ja MEI driver nalozi najnovejsi ane.
Anney ::
Jaz sem imel podobne težave, pa je bil kriv, nikoli nisem točno izvedel, vendar sumim driver za diske (sata). Računalnik je po parih nadgradnjah samega jedra WIN10 sistema začel spet delovati in danes ista konfiguracija dela tekoče na WIN10 CU updejtu in tudi na AU je delalo ok, vmes pa nekaj časa ne. Nobena komponenta ni bila zamenjana. Beri na linku spodaj.
Težava Microsoft-Windows-Kernel-Power
Pero_SLO ::
Odlično, hvala za info. Sedaj saj vem, da je zadeva brez glave in repa ter da je problem na strani MS/driver writerjev...
Ve kdo za kakšen vredu program, ki ti pokaže katere driverje potrebuješ in katere ne, da ti odstrani še kakšno navlako od driverjev...?
Hvala in LP,
Peter
Pero_SLO ::
Na novo naložil zadnje win10 in ni nič pomagalo, takoj začelo rebootat... Po odklopu vseh dodatnih diskov in grafične v biosu, sedaj dela vse normalno. Po postopnem priklapljanju stvari nazaj se je izkazalo, da Samsungov 830 SSD disk in grafična povzročata rebootanje. Skupaj, vsak posamično, nima veze...
LP,
Peter
LP,
Peter
Pero_SLO ::
Bios reset, pa grafo al disk se v kak drugi slot poskusit.
Te http://www.nvidia.com/download/driverRe... driverji so zgleda rešili problem z grafo(da se ne bom prehitro veselil :) ).
pa updejt firmware-a na ssdju
Mam Samsungov Magician software gor in za 850 SSD mi je ponudil možnost upgrejda FW-ja in sem ga, za 830 pa javi da je zadnji gor.
Tko da je mogoče računalnik zrihtan, razen 830 SSD-ja :) .
LP,
Peter
Anney ::
Verjetno se ti tepejo driverji za diske. To sem jaz domneval drugega skoraj ni bilo mogoče. Bilo je mirno tudi do 2 dni ali pa reset na 10 min, čisto random. Kater OS imaš (verzija). Tukaj imaš custom driverje, poskusi še s kakšnim od teh. http://www.win-raid.com/forum.php
Pero_SLO ::
Verzija je 1703 OS Build je 15063.250 nevem katero je pomembno. Zanimivo je da mi zagon TeamViewer-ja brez inštalacije tudi resetira računalnik po tanovem... Samsung 830 SSD mi pa restarta računalnik, samo če v explorerju/total commanderju mal pobrskam po njem... Ker sem probal 5x zagon TeamViewer-ja in enako za disk in vsakič reboot računalnika... Kaj so to čudne napake/nekopatibilnosti...
LP,
Peter
Anney ::
Daj mi še podatek za krilnik IDE/ATA. Jaz imam tega in mi sedaj dela ok. verzija 12.9.4.1000 (iaStorA)
https://www.dropbox.com/s/xede1iyfw08kj...
- spremenilo: Anney ()
Pero_SLO ::
Kje to pogledam, sem pod system info->storage->IDE pa piše Standar SATA AHCI Controller, to rabiš al?
LP,
Peter
Anney ::
Tukaj je samo en problem, da imaš ti novejši chipset Z170 in je treba najti vrjetno duge, poskusi te pognati, če ne odgovarjalo tako ali tako ne bo zagnalo inštalacije.
Anney ::
Tukaj imaš te svoje driverje za AHCI, poglej pa še v biosu ali imaš AHCI vklopljen.
v13.2.8.1002
v14.8.16.1063
v15.2.16.1060
https://www.dropbox.com/s/4ydddyj2vs4nl...
v13.2.8.1002
v14.8.16.1063
v15.2.16.1060
Anney ::
Problem tega je, da je res windows kriv, ker se nekatri driverji tepejo med sabo, ali pa navaze samsung win10. Nekaj od tega. Če imaš kakšen drug disk poskusi sistem poganjat z drugega diska za kakšen dan, pa vidiš če ti bo isto delalo. Spremljaj eventlog.
klinker ::
Seveda je...kolko kiksov sem dozivel na 10ki, jih se na nobenih winsih nisem. Se Vista je bolj kvaliteten OS.
» | SSD+HDD računalnik ne zazna HDDOddelek: Pomoč in nasveti | 4343 (4109) | styled |
» | windows 7 reset brez error-jaOddelek: Pomoč in nasveti | 2782 (2392) | mtosev |
» | SSD disk-Računalnik zamrzneOddelek: Pomoč in nasveti | 4773 (4205) | styled |
» | Win problemOddelek: Strojna oprema | 2316 (2072) | fantasycamp |
» | Diablo 3 zatikanje?Oddelek: Strojna oprema | 1361 (1142) | bluefish |
