Forum » Loža » LinkedIn spam?
LinkedIn spam?
Rias Gremory ::
Živjo,
šest dni nazaj sem dobil e-mail z zadevo "I'd like to add you to my professional network on LinkedIn" češ, da bi nek Simon rad ostal v kontaktu z mano (Simon *priimek* would like to stay in touch on LinkedIn.).
Mail prihaja iz messages-noreply@linkedin.com.
Na LinkedIn se nisem nikoli registriral, sem 95% prepričan.
Sem že nekajkrat slišal, da LinkedIn spama. Torej me zanima ali je to njihov legit spam, da se registriram ali je phishing?
Lep pozdrav
Lep pozdrav
Matko ::
Lahko je scam, lahko pa je res od LinkedIna-a.
Ko se uporabnik registrira na LinkedIn,
ta pridobi dostop (uporabnik seveda klika samo DA in naprej) do vseh možnih seznamov elektronske pošte in potem pospama vse naslovnike.
Rias Gremory ::
Preglej headerje oz. kako je mail prišel do tebe.
Ne vem točno kaj je treba pregledat, lahko pomagaš?
Moj mail je bil tam kjer je "foo@gmail.com".
Delivered-To: foo@gmail.com Received: by 10.55.140.65 with SMTP id o62csp1587045qkd; Mon, 11 Jul 2016 02:30:04 -0700 (PDT) X-Received: by 10.55.16.232 with SMTP id 101mr25433823qkq.151.1468229404229; Mon, 11 Jul 2016 02:30:04 -0700 (PDT) Return-Path: <m-3twap82piq7z79kk4hyle3dxszf32vj9qcuu6qm0j8z7ix6dej7sm@bounce.linkedin.com> Received: from maile-ac.linkedin.com (maile-ac.linkedin.com. [2620:109:c006:104::195]) by mx.google.com with ESMTPS id j9si796456qke.155.2016.07.11.02.30.04 for <foo@gmail.com> (version=TLS1_2 cipher=ECDHE-RSA-AES128-GCM-SHA256 bits=128/128); Mon, 11 Jul 2016 02:30:04 -0700 (PDT) Received-SPF: pass (google.com: domain of m-3twap82piq7z79kk4hyle3dxszf32vj9qcuu6qm0j8z7ix6dej7sm@bounce.linkedin.com designates 2620:109:c006:104::195 as permitted sender) client-ip=2620:109:c006:104::195; Authentication-Results: mx.google.com; dkim=pass header.i=@linkedin.com; spf=pass (google.com: domain of m-3twap82piq7z79kk4hyle3dxszf32vj9qcuu6qm0j8z7ix6dej7sm@bounce.linkedin.com designates 2620:109:c006:104::195 as permitted sender) smtp.mailfrom=m-3twap82piq7z79kk4hyle3dxszf32vj9qcuu6qm0j8z7ix6dej7sm@bounce.linkedin.com; dmarc=pass (p=REJECT dis=NONE) header.from=linkedin.com DKIM-Signature: v=1; a=rsa-sha256; c=relaxed/relaxed; d=linkedin.com; s=proddkim1024; t=1468229403; bh=HLbIEvNHKZrbVNOJ+BYFj529kCQ2xUGWCdAj+7zc0xk=; h=From:Subject:MIME-Version:Content-Type:To:Date:X-LinkedIn-Class: X-LinkedIn-Template:X-LinkedIn-fbl; b=bA1i9xEoEdKPGjt9PMSydzMHushUnRoEhseJcreqalHyCaU1P6Urdu9JM8NxxNHEd eV48JI0OmWePKuUKSY0rwZgpkU1JwbgquSSAtYeew+UEBflMV110Dg59ZR+dz8Yivt 83J27hSt760hC4+Lvp+S8xTHmGO5BIJpQdJsbJVA= From: Simon foo <messages-noreply@linkedin.com> Message-ID: <2102825746.7450403.1468229403318.JavaMail.app@ltx1-app5318.prod.linkedin.com> Subject: I'd like to add you to my professional network on LinkedIn MIME-Version: 1.0 Content-Type: multipart/alternative; boundary="----=_Part_7450401_2051723844.1468229403315" To: <foo@gmail.com> Date: Mon, 11 Jul 2016 09:30:03 +0000 (UTC) X-LinkedIn-Class: INVITE-GUEST X-LinkedIn-Template: invite_guest X-LinkedIn-fbl: m2-aszvaauijax0etb54wmicewil4yrjjflqeci7x0ph1mgykicpoor79a5tmzlfzwnucmvwq1pje6spmh6q9qx4cpy3n7926zrex4ay9 X-LinkedIn-Id: 0-iqhtvjyn-p6 List-Unsubscribe: <mailto:list-unsubscribe@linkedin.com?subject=unsubscribe/AQFdQQ9ldv7U4QAAAVXZSsK2qQmGtNoPn5ieH3fxHMJPHHKn8EC6gKZnd5RuCmbv-zpD6CjUJM97m46C/0-iqhtvjyn-p6/m2-aszvaauijax0etb54wmicewil4yrjjflqeci7x0ph1mgykicpoor79a5tmzlfzwnucmvwq1pje6spmh6q9qx4cpy3n7926zrex4ay9> Feedback-ID: invite_guest:linkedin
by mx.google.com
Zgleda kot njihov "legit spam".
Jap, to dobuš kadar nekdo klikne invite na tvoj email, ki mu ga LinkedIn predlaga. Tak da v bistvu te spema ta oseba, LinkedIn samo pomaga pri spemanju.
Eni ljudje so pač malce preveč naivni pa next klikujejo, človek ne ve ali biti jezen na tega človeka ali na LinkedIn ali na oba:)
Rias Gremory ::
Hmm ja potem je pa očitno res legit, ker piše kje dela in sem bil nekako v stiku z tem podjetjem pred kratkim čeprav te osebi maila nisem posredoval. Fucking spam.
Hvala vsem.
Hvala vsem.
Rias Gremory ::
Mimogrede, vprašanje za tiste, ki ste na LinkedIn-u.
Sprejmete "prijatelje" oz. karkoli že ima LinkedIn tudi, če jih ne poznate? Ste že dobil kakšen šiht preko LinkedIna?
Jaz probam bit zelo selektiven(to da poznam zgolj en izmed pogojev), tudi pri Facebooku sem, tukaj še toliko bolj.
Načeloma ne dodajam oseb, ki niso karierno na istem področju. Čeprav če me kdo ki ga poznam doda, ga pač sprejmem...
amacar ::
Na linkedinu js sprejmem vse, ker ga ne uporabljam aktivno (enkrat na teden, dva tedna pogledam če je kako obvestilo). Je pa padlo že kr nekaj ponudb, a zaenkrat še nisem zainteresiran za preselitev v tujino.
Na FB pa sprejmem samo tiste, s katerimi se aktivno pogovarjam, imam le cca 60 prijateljev.
Pa so tale sporočila "<spisek firm> are looking for candidates like you." resna?
Torej si že nekako delno v postopku, ali gre zgolj za spam.
Mislim, a je kdo dejansko iz tistih firm kliknil na tvoj profil in potem "We're interested" ali pa LinkedIn samo tak pošilja spam "zaradi lepšega"? (v smislu: firme napišejo lastnosti, ki jih iščejo, LinkedIn pa vidi, da se ujemaš vsaj 75% in že pošilja spam)
kunigunda ::
Rias Gremory je izjavil:
Hvala vsem.
Ni treba da ve tvoj mail, ce imas tako nastavljeno v nastavitvah profila. Lahko te najde po imenu, te linkedin suggesta (sploh ce si 2nd connection) in klikne Connect.
Tko da ni kle spama.
» | Microsoft kupil LinkedIn (strani: 1 2 )Oddelek: Novice / Nakupi / združitve / propadi | 21913 (13793) | Malajlo |
» | Microsoftu bržkone tudi evropska zelena luč za prevzem LinkedInaOddelek: Novice / Nakupi / združitve / propadi | 7993 (6624) | FTad |
» | LinkedIn izgubil 6,5 milijona geselOddelek: Novice / Varnost | 18872 (16444) | Jst |
» | Dobičkonosen LinkedIn kupuje SlideShareOddelek: Novice / Nakupi / združitve / propadi | 6717 (5679) | Iatromantis |
» | V profilih na LinkedIn manj pomembnih laži kot v življenjepisihOddelek: Novice / Znanost in tehnologija | 3385 (2602) | Invictus |
