Prijavi se z GoogleID
P: DELL U2913WM
P: DELL U2913WM
Prodam 29" DELL monitor:
 DELL U2913WM
DELL U2913WM
Diagonala: 73.02 cm / 29 inches (28.75 inch wide viewable image size)
Active Display Area (H x W): 672.77 x 283.82 mm
Optimal resolution: 2560 x 1080 at 60 Hz
Aspect ratio: Ultra widescreen (21:9)
Pixel pitch: 0.09 (H) mm x 0.26 (V) mm
Brightness: 300 cd/m² (typical), 50 cd/m² (minimum)
Adjustability: Height-Adjustable stand, tilt, swivel and built in cable-management, capacitive touch OSD controls
Color Support: Color Gamut (typical): sRGB >99%, 82% (CIE 1976)*
Color Depth: 16.7 million colors
Contrast Ratio: 1000 to 1 (typical), Dynamic Contrast Ratio: 2 Million:1 (Max)
Viewing Angle: 178° vertical / 178° horizontal
Response Time: 8ms (grey to grey)
Panel type, surface: In-plane switching, anti-glare with hard coat 3H
Backlight Technology: LED
Display Type: Widescreen Flat Panel Display
Flat Panel Mount Interface: VESA
Display Screen Coating: Antiglare with hard-coating 3H
Connectivity:
1 Dual Link Digital Visual Interface connectors (DVI-D) with HDCP
1 DisplayPort 1.2 (DP)
1 Mini DisplayPort 1.2 (mDP)
1 High Definition Multimedia Interface (HDMI)
1 Video Graphics Array (VGA)
1 USB 3.0 upstream port
4 USB 3.0 downstream ports
1 DisplayPort out
1 Audio out
DC power connector for Dell Soundbar (AX510)
Dodam USB 3.0 kabel za povezavo med monitorjem in PC-jem
Cena 300€
ZS ali 031 440 308
P: Malo boljši računalnik
1800 €
Oddelek: Mali oglasi
0469 (469) WizzardOfOZ
P: Asus ROG Strix XG32VQ
450 €
0201 (201) Kayzon
