Forum » Programska oprema » Skype problem
Skype problem
WaterBoy ::
ZaLoMaT ::
Verjetno je sesutje posledica Skype goes down globally, investigation underway (update: restored), vendar bi sedaj moralo že vse gladko delovati.
WaterBoy ::
Hmm. Še kr mi ne dela. Tole piše pod detajle problema:
Problem signature:
Problem Event Name: APPCRASH
Application Name: Skype.exe
Application Version: 5.1.0.112
Application Timestamp: 4d4037c2
Fault Module Name: Skype.exe
Fault Module Version: 5.1.0.112
Fault Module Timestamp: 4d4037c2
Exception Code: c0000005
Exception Offset: 006c0355
OS Version: 6.1.7600.2.0.0.256.48
Locale ID: 1060
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=...
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
Problem signature:
Locale ID: 1060
misek ::
Izbris datoteke shared.xml pomaga: http://heartbeat.skype.com/
Windows
If the Skype icon is displayed in the system tray at the bottom right of the screen, right-click it and select Quit.
Click Start, type "run" and press Enter. (On Windows XP: Click Start and then Run.)
Type "%appdata%\skype" and click OK.
Locate and delete the file shared.xml. The file may be displayed as shared if file extensions are not displayed by default on your computer.
If you cannot find this file:
Type "control folders" and click OK.
In the View tab, ensure that Show hidden files and folders is enabled.
Repeat the instructions from the beginning.
Restart Skype.
Mac
Open Finder and locate the following folder:
~/Library/Application Support/Skype
Delete the file shared.xml.
Restart Skype.
The ~ sign means your home folder. You can find your home folder by opening Finder and selecting Go > Home from the menu bar or pressing Command (Apple), Shift and H keys at the same time.
Linux
Go to the following folder:
/home/YourLinuxUserName/.Skype
Restart Skype.
The Skype folder is a hidden folder - please check Show hidden files in your file browser to view and access it.
jurre ::
Pri meni tudi to ni pomagalo, kakor sem nalozil verzijo 5.3 se je sesula ob vpisu (tudi frisen install, ne upgrade.)
Zdaj sem dal nazaj 4.1, ker imam edino zloadano celo offline instalacijo (5.3 mi je loadal skoraj 1h pri online instalaciji).
- spremenil: jurre ()
tv6865 ::
Pozdravljeni,
da ne odpiram nove teme bom kr tule nadaljeval.
Pri meni se zadnje čase skayp sesuva konatantno. Ko se prijavi mi v roku 2s napiše Skayp ne deluje več Zaradi težav je bilo ustavljeno pravilno delovanje programa .....
Sem poskušal z ponovno namestitvijo pa isto. Kaj bi bil vzrok?
» | WPF in windowsi xpOddelek: Programiranje | 706 (583) | detroit |
» | Težave ob namestitvi in odpiranju določenih programovOddelek: Pomoč in nasveti | 1320 (1224) | Duhec |
» | netbook se mi sam od sebe resetira BSODOddelek: Pomoč in nasveti | 1036 (1003) | neeno |
» | Word - ne odpre doc fajlaOddelek: Pomoč in nasveti | 1743 (1548) | Fave |
» | Dodajanje bližnice v meni desne tipke na miškiOddelek: Pomoč in nasveti | 1363 (1248) | vres.ales |
